Quick LED Turn Signal Question
  • Lifted94XLT
  • Lifted94XLT's Avatar Topic Author
26 Jul 2011 19:20
#465123
ok, I've installed Front and rear LED turn signals (the Rears are brake/tail/turn) on my 82 Kz550 LTD.... I installed the rear first and got everything wired up, planning not to run any front signals, then decided I should probably run them when the wouldn't flash, just stay lit solid, even after I installed an Electronic Flasher for LEDs....
I ordered some front LED signals off eBay and wired and installed them last night... Turned on the blinker and the rear came on solid, the front didn't come on at all, and the cluster indicator came on solid... ok, so I plugged in a factory turn signal and everything worked, and blinked, just fine.... so I take it I still need to wire in a resistor even WITH an electronic Flasher Relay already in place or have I missed something?
Thanks for any help.... tryin to get this buttoned up before I take it for its first ride.
--Ryan
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
Re: Quick LED Turn Signal Question
26 Jul 2011 19:28
#465127
You're sure you have a NO-LOAD electronic flasher?
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • Lifted94XLT
26 Jul 2011 19:30
#465128
mtbspeedfreak wrote: You're sure you have a NO-LOAD electronic flasher?
No.. all I know is that it said its for LED Lights.... didn't know there was more than one honestly.
  • MFolks
  • MFolks's Avatar
26 Jul 2011 19:41
#465131
The following user(s) said Thank You: Lifted94XLT
  • Lifted94XLT
26 Jul 2011 19:47
#465137
Thanks for the info!! I assume the CF12ANL-01 from superbrightleds.com will work too then....
www.superbrightleds.com/cgi-bin/store/in...Disp=%2Fflashers.htm
  • mtbspeedfreak
26 Jul 2011 19:55
#465143
Lifted94XLT wrote: Thanks for the info!! I assume the CF12ANL-01 from superbrightleds.com will work too then....
Yep, right on. Otakar suggested the CF12 flasher which is what I got, I have absolutely no gripes about that flasher whatsoever.
2000 ZRX 1100
  • otakar
  • otakar's Avatar
26 Jul 2011 21:57
#465169
Yup the CF-12 flasher is the only one that works right out of the box.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Lifted94XLT
27 Jul 2011 08:13
#465259
otakar wrote: Yup the CF-12 flasher is the only one that works right out of the box.
Thanks guys!! I guess I will go ahead and order that and hope it works!!
--Ryan
