spark plug wires... which size for GPZ 550?
- kscanuck785
16 Jul 2011 15:51
I'm wanting to pick up some colored wire but I see 7MM and 8MM, which one is the right one for my GPz550?
and what about the angle? 45,90 or 180?
thanks!
thanks!
French Canadian exiled in Kansas since 2005
1983 GPZ 550~~rebuilder
1989 1st gen. Toyota 4 Runner
our gun shop~ specialized in custom AR's
www.g-trigg.webs.com/
my bail bond business
10-4bailbonds.webs.com/
Re: spark plug wires... which size for GPZ 550?
16 Jul 2011 15:55 - 16 Jul 2011 15:59kscanuck785 wrote: I'm wanting to pick up some colored wire but I see 7MM and 8MM, which one is the right one for my GPz550?
thanks!
Would suggest considering the 7mm Dyna plug wires from Z1 Enterprises, which come with the caps (boots) pre-installed.
www.z1enterprises.com/SearchResult.aspx?...eyWords=plug%20wires
If the stock wires are 7mm, the 8mm would imo be overkill, and may not fit properly into the coils without some hacking on the insulation.
Last edit: 16 Jul 2011 15:59 by Patton.
The following user(s) said Thank You: kscanuck785
- kscanuck785
16 Jul 2011 16:08
they don't have white ...
and the grey is 8mm....
I will keep looking...
- hocbj23
16 Jul 2011 16:19
Im running Taylor 7mm wires on mine.Built in caps and they come in Kawi green as well.bj
