81 KZ750 E main fuse gets very hot. PLEASE HELP!
- IDGY_KZ
15 Jul 2011 01:18
Hey all Kz'rs
I was out for a great ride last night with my dad, coming home from a cruse night. about two miles away from home durring a right turn, the entire bike shut off, lights and everything. checked the fusses on the side of the road and found that all the solder melted inside the main 20A fuse. there was a pool/ribbon of solder running through the fuse, so I had my dad run to the gas station to pick up some fuses. got the new fuse in, bike turned on (after cleaning the fuse holder leads).
Thankfully I made it home (very late) and put her to sleep.
Today when I got home from work I checked the fuse while the bike was on and running, the main leads got very hot.
I fiddled around with all the wiring, under the seat and in the headlight to see (visually inspect) the wires and found nothing out of the ordinary i.e. burnt/damaged wires.
Where could the problem be coming from, causing the fuse to get hot enough to melt solder but not blow the fuse element? What can I do to check the system?
Thank you in advance!
motorcycle
1981 KZ750E
1978 SUZUKI GS1000
bicycles
1984 raleigh marathon single speed
1987 custom schwinn la tour
1998 schwinn homgrown xt race bike
1981 KZ750E
1978 SUZUKI GS1000
bicycles
- MFolks
Re: 81 KZ750 E main fuse gets very hot. PLEASE HELP!
15 Jul 2011 01:39
Take some cotton swabs and metal polish and throughly clean the fuses & fuse clips. Then get some electrical contact cleaner(I like the brand called De-Oxit) and apply some to the fuse clips.
Also do this:
Cleaning Motorcycle Electrics
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website.Available at Radio Shack Stores and other electronic supply places.
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach.
Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting).I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
Why WD-40 Should Not Be Used On Motorcycle Electrical Items.
For many years, I was proponent of the use of WD-40 on fuse clips, fuses, switches and connectors. After hearing of other peoples experience with intermittent and sporadic activity, I shrugged it off as maybe they did something wrong in the application of the product.
It wasn’t until the time I rode my 1982 GPz1100 B2 model to downtown San Diego that I encountered the problems others had gone through.
After concluding my business downtown, I walked to where my bike was parked, turned the key to unlock the forks, and prepared to start the engine. The key was in the "On" position, yet I had no lights in the dash panel, the fuel pump was not running(I have FI), and the horn and tail light were not working.
Puzzled as to why nothing electrical was happening, I remember my earlier conversations about how WD-40 will over time become a non-conductor(more like an insulator). I had some pieces of 400 and 600 grit sandpaper in my tool kit and with them was able to scratch away the coating from the WD-40 on the fuses and clips.
After removing the insulating film, the bike started and ran like it should. Since that time, I’ve told people about the problem with WD-40. If you must use a contact cleaner, I recommend getting some "De-oxit" from Radio Shack Stores or any good electronic supply store.
Also do this:
Last edit: 15 Feb 2013 11:05 by martin_csr.
- RonKZ650
15 Jul 2011 11:38
This has been a problem with these bikes since they were new. Fuse clips get dirty/corroded the fuse will heat and eventually melt. Also due to the heat most likely the plastic in the fuse box that puts extra pressure on the clips to make a tight connection to the fuse has melted, so insufficient pressure on the clips to the fuse it will run hot even with perfect contact. The best thing to do is change the entire fuse box to modern blade fuses. Otherwise tie a ziptie around the fuse clip to secure it to the fuse with more pressure.
- IDGY_KZ
15 Jul 2011 13:43
Thanks everyone!! I will try a thorough cleaning first and see how the fuse performs. then go from there.
motorcycle
1981 KZ750E
1978 SUZUKI GS1000
bicycles
1981 KZ750E
1978 SUZUKI GS1000
bicycles
- MFolks
15 Jul 2011 14:19
Fuse And Fuse Holder Designations
1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1” long. Most good auto parts stores can get them for you. They are ¼” in diameter.
2. The more common AGC is 1 ¼” long and may not fit the smaller fuse clips. Again, ¼” in diameter.
3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
4. These fuses can fail internally but look good, only by removing them from the clip and electrically continuity checking with either a self powered test light, or a multimeter set on OHMS can they be determined to be in good shape.
5. A physical inspection of the metal end caps for tightness will tell you if the fuse is serviceable.
6. Most modern motorcycles are now using the automobile “Blade” style fuse with the designation of ATC or ATO.
7. The reduced sized “Mini” Blade style fuse holder uses the ATM size of fuses.
8. If the fuse and fuse holder overheat, it could soften or anneal the grip of the clip, it might require squeezing the clip to restore the tightness.
9. A list of where to purchase “Blade” style fuses and holders:
www.waytekwire.com order.waytekwire.com/productdetail2/M50/...20%20%20%208%20FUSE/
www.rallylights.com www.rallylights.com/detail.aspx?ID=765
www.delcity.net/store/6!way-fuse-blocks/p_10822.a_1
10. A source for the glass tubed AGX fuses:
www.boatownerswarehouse.com/browse.cfm/2,4986.html
