'82 KZ1000J - will it handle dual headlights?
- Marks951
- 1982 KZ1000J
09 Jul 2011 19:32
Will the charging/electrical system handle two headlights? I would be running H4 lights in both. Any thoughts?
- MFolks
Re: '82 KZ1000J - will it handle dual headlights?
09 Jul 2011 20:11
What wattage? two(2)35 watts or (2) 50 watts?
Let's say (2) 35 watt bulbs for a total of 70 watts. To figure current(Amps) the formula is W/E or 70/12 with 12 being the voltage. Using a calculator it figures out to 5.83333 or lets say 6 amps.
If you're going with 2 50 watt bulbs, the formula is the same, W/E or 100/12 equals 8.3333 or 9 amps current draw. Either way, a relay will be needed as the headlight switch electrical contacts will quicklt burn out from overload. The headlight circuit could be used on the relay's energizing coil circuit.
Relay Types & Wiring Information
www.the12volt.com/
www.2carpros.com/how_to/how_do_i_check_a_relay.htm
The charging system might support it, but if it were me, I'd get an upgraded alternator and regulator/rectifier from www.electrosport.com as they are designed to produce more power at lower rpm's than what the stock system does.
www.the12volt.com/
- MFolks
09 Jul 2011 20:20
If you do decide to go with the dual H4 bulbs, the next minor problem might be in locating a location to mount the relay. Try to install it inside an enclosure to reduce water/moisture corrosion on the electrical connections.
www.mcmelectronics.com/product/26-1942 (A prewired relay connector and relays)
Driving Light Mounts & Wiring
www.gadgetjq.com/wiredrivinglights.htm
www.shadowstuff.com/links/products_light_mount.htm
www.valueaccessories.net/Light%20Bar%20Wiring.htm
www.demonscycle.com/Lights-and-Blinkers/...or-p6205748-1-2.html
LED Driving Lights
www.webbikeworld.com/lights/motorcycle-driving-lights/
www.whitehorsegear.com/bikevis-bullets
www.whitehorsegear.com/cree-high-intesity-led-running-lights
www.jpcycles.com/product/3100441
LED Driving Lights
- Marks951
- 1982 KZ1000J
10 Jul 2011 13:49
MFolks
Thank for your response. I have been studying and shopping your links all morning! Great resources. Thanks again.
Mark
Mark
- MFolks
10 Jul 2011 15:09
Happy I could offer advise/where to shop. I love a good motorcycle electrical mystery now and then.
- mark1122
- Keep twisting it
10 Jul 2011 18:37
u may want to consider 2 hid lights. they are 35watts and u could run 1 for low and the other for high beam. then no relay required.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bountyhunter
11 Jul 2011 04:08
I used to run a second 55W halogen driving light when I cruised the freeway late night. I would not touch the horn or turn signals while I had both lights on.
You can free up some alternator wattage by replacing your brake light, turn signals, running lights with LED types.
- SPARKY47
- 1980 KZ500 B2
11 Jul 2011 20:41
Flash alternatively(as in an astable),faster than persistance of vision.
No net increase in current consumption.
I think.:whistle:
I think.:whistle:
1980 KZ500 B2
- steell
12 Jul 2011 00:47SPARKY47 wrote: Flash alternatively(as in an astable),faster than persistance of vision.
I think.:whistle:
With incandescents? I doubt persistence of vision would be a problem.
Bulb life on the other hand, just might :laugh:
A little complicated though.
Now if you have about $400 (or was that each?) to spare for a pair of LED headlights, power consumption wouldn't be a problem.
- Tested
15 Jul 2011 03:31
Great thread. I look forward to doing some further reading. The possibilities are endless.
2008 KLR 650
1977 KZ 750
_____ Have had _____
1981 KZ 440
1970's CR 125
1982 KLX 175
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
