Rectifier issue on KZ900B
- readtaintor
07 Jul 2011 12:12
Forum Members,
I have a '76 KZ900B that occasionally blows the 20A main fuse. Using an ohmmeter it appears that the rectifier's 2 of 4 diodes are shot. Are any of you aware of a generic/less expensive replacement or is it possible to replace the 2 diodes? Any advice would much be appreciated!
- MFolks
Re: Rectifier issue on KZ900B
07 Jul 2011 16:34
Try here:
www.oregonmotorcycleparts.com
The following user(s) said Thank You: readtaintor
- loudhvx
07 Jul 2011 17:48
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationThere should have been 6 diodes, if I recall correctly.
As Mfolks says, oregonmotorcycleparts is your best bet due to the warranty and price.
However, you can make one pretty cheaply if you need it today:
home.comcast.net/~loudgpz/GPZweb/RegRec/...3phaseRectifier.html
But there is a new option as well, that some have used with success. They take a long time to get, and I'm sure there isn't much of a warranty.
I just spotted this one too:
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- otakar
07 Jul 2011 17:50
I have used the SQL100A and love it. It's worth every penny.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- TomW
- Keep the blue side up.
10 Jul 2011 09:22
I replaced my OE rectifier with an electronic rec/reg. You can have the old rectifier for postage cost if you want it. It's out of a '78 KZ1000 LTD.
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
