Ignition Switch Assembly Discontinued?
  • cnorman27
  • cnorman27's Avatar Topic Author
06 Jul 2011 12:52
#461306
I got a new ignition switch from Z1 for my 1982 KZ1100 Shaft and then found out that it is the wrong one.
The one I need is 27005-5019 but Chris at Z1 told me that it's discontinued and he doesn't have a source for it. Anyone know where I can get this?
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: Ignition Switch Assembly Discontinued?
06 Jul 2011 15:14
#461335
Is that a 9 pin switch? roy
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
06 Jul 2011 15:55
#461353
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • cnorman27
Re: Will attach a picture later.
06 Jul 2011 16:12
#461360
It occurs to me that I don't remember exactly what it looked like, I'll take a picture of it tonight.
  • wagonmaster69
  • wagonmaster69's Avatar
  • 78 KZ1000A2 / 82 KZ1100 Spectre
06 Jul 2011 18:45
#461385
No its looks different.
It dose not have a thick shaft (no laughing) but a thiner one for the upper tree.
  • wagonmaster69
06 Jul 2011 18:51 - 06 Jul 2011 18:51
#461387
Last edit: 06 Jul 2011 18:51 by wagonmaster69.
  • cnorman27
06 Jul 2011 18:51
#461388
Yep, it's the thin one. The one that Z1 has is the wide one that actually has the "Run/Park/Lock" on the switch.
  • wagonmaster69
06 Jul 2011 18:52
#461389
I went through the same problem with mine.
  • cnorman27
06 Jul 2011 18:59 - 06 Jul 2011 19:08
#461392
I give up, I thought that was the right one and paid for it. Then, I realized that it isn't what I need, the part number is right there on it too, it's just a lock, not ignition.
Last edit: 06 Jul 2011 19:08 by cnorman27.
  • wagonmaster69
07 Jul 2011 01:42
#461469
wagonmaster69 wrote: cgi.ebay.com/ebaymotors/Kawasaki-KZ1100-...&hash=item19b9f5e111
this is the one you need.
OOPS got the wrong one.
  • wagonmaster69
07 Jul 2011 02:10 - 07 Jul 2011 02:12
#461473
Last edit: 07 Jul 2011 02:12 by wagonmaster69.
  • martin_csr
  • martin_csr's Avatar
Re: -
07 Jul 2011 09:32 - 15 Feb 2013 10:49
#461494
Last edit: 15 Feb 2013 10:49 by martin_csr.
