gel battery?
- captain awsum
gel battery?
06 Jul 2011 01:39
so I have a project 78kz400, I'm lookin to order some stuff off of the same site to save on shipping. In looking I found a 'gel battery' (
www.motorcycle-superstore.com/Mobile/Ite...=28402&ModelId=15020
)that says it withstands vibration and temp changes better, and less likely to leak,etc. Any idea if it's woth the extra $30 or so dollars on a battery? And any idea bout the quality of that site and its parts? Thanks
I have a project 78 kz400c1 (currently in pieces)
www.kz400.blogspot.com
- bountyhunter
Re: gel battery?
06 Jul 2011 01:52
You only care if it's leakproof if you are planning to go upside down.... I think gel cells are OK but you get more amp-hour capacity for your money with a conventional wet cell. I don't think gel cells are superior for temp range, they both have a similar temp coefficient.
The following user(s) said Thank You: captain awsum
- ELCouz
Re: gel battery?
08 Jul 2011 02:04 - 08 Jul 2011 02:04
Check this thread -->
kzrider.com/forum/2-engine/453911-battery-replacement#453992
Gel is the same thing as AGM in the sense that is not water refillable... it's not tolerant to overcharging as a regular old wet lead acid battery (when overcharged just add distilled water and you're done).
Be sure your rectifier/regulator is new or in top shape when using sealed batteries (GEL and AGM)!
regards,
laurent
regards,
laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Last edit: 08 Jul 2011 02:04 by ELCouz.
- otakar
Re: gel battery?
08 Jul 2011 08:49 - 08 Jul 2011 08:51
I agree with both of the previous two posts. I do NOT think they are worth the money under any means. I used to be in the Rechargeable battery business some years ago.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 08 Jul 2011 08:51 by otakar.
