r/r on 82 kz1100 spectre D1
- wcrider62
03 Jul 2011 07:06
OK whats the trick for geting the magnet part of the stator off the bike ??? got a replacement stator but brushes 1/2 inch smaller than the original so I figured just change the maget tooo??
1982 kz1100 spectre D1
- TeK9iNe
- What did you do!?!
Re: r/r on 82 kz1100 spectre D1
03 Jul 2011 11:54
Not sure the exact size, but you need a heavy grade bolt to use as a puller. Sometimes the rear axle bolt is the correct size (M18 I think...). Usually a black bolt - like grade 10 or higher I believe.
You just turn in the bolt till it stops, then whack it good with a large mallet ( I prefer a sledge with a couple towels rapped around), and then tighten the bolt some more, whack it, tighten it real hard, whack it...
You get the picture - it'll pop off after several applications.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
03 Jul 2011 12:06
Don't miss and hit the magnet.:pinch:
- clutch
- I wish I had a tad more patience to do it better!
29 Sep 2011 02:31
Wait a minute! The stator rotor isn't bolted on? It just sits in place magnetically? Is there another method to remove this if you do not have a puller??
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
Wish List:
Z1 (need I...
- MFolks
29 Sep 2011 02:43
Let's see, the stator(the wire windings) sits inside the engine side cover, secured with 3 fasteners. The rotor is bolted to the crankshaft. This part has the magnets, so when it spins,a magnetic field produces alternating current(maybe 50 volts).
- clutch
29 Sep 2011 02:52
Right, I'm familiar with the stator, but I am rewiring the 750, and noticed a little oil when I pulled the stator cover off. I want to remove the magnet rotor to see what's going on behind there, but I'm not really sure how to do it. Came across this post and thought I missed something. So....how do I hold that sucker still to remove the bolt? And after that I need a puller?
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
- MFolks
29 Sep 2011 03:20
The small amount of oil is normal, it cools the stator windings and lubricates the starter clutch parts. As for removing the rotor, I'd think an impact wrench would work the best.
- clutch
29 Sep 2011 03:23MFolks wrote: The small amount of oil is normal, it cools the stator windings and lubricates the starter clutch parts. As for removing the rotor, I'd think an impact wrench would work the best.
Interesting. I have an impact wrench, so I will see how that works for me tomorrow. No harm in still having a look to make sure everything is as it should be behind there. Thanks for the help
~Clutch
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
30 Sep 2011 01:11
I have that same bike but ratted out.
Went to Bert's its a huge bike shop here in So Cal.
Anyways got the bolt for a little over $10.
Just put it in tighten it down and get a impact and it comes right off.
But when you put it back on do it in increments of 10lbs till you get the final lbs with losing the bolt each time.
I did it 5 times before the final set lbs.
