LH Z1 ent repro switch housing
  • mvent
  • mvent's Avatar Topic Author
28 Jun 2011 22:26
#460044
About to connect LH early style switch housing repro from Z1 ent to main harness of my 78 KZ1000, I am electrically challenged,so by any chance does someone have a photo of how they wired together? Seeing that the wire colors are not the same, it would be a great help.:unsure:
Thanks
Mike
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • mvent
Re: LH Z1 ent repro switch housing
30 Jun 2011 20:42
#460344
Anyone?
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
30 Jun 2011 21:32 - 30 Jun 2011 21:32
#460352
The replacement did not come with a color chart for the wires on it?
If not you will either have to ring them out (use a meter) or give Z1E a call/email to see if they can tell you.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
Last edit: 30 Jun 2011 21:32 by KZ_Rage.
  • KZ_Rage
  • KZ_Rage's Avatar
30 Jun 2011 21:40
#460353
Is this the switch you bought (Z1 LH)
Are you trying to cut these wired ends off and the ones on your original harness and splice them together? Need your schematic for the specific model you have (A2, A2A, B2C1, C1A or D1) or you can look at the old switch to see where what color wire goes where on it.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
30 Jun 2011 21:51 - 30 Jun 2011 21:53
#460358
mvent wrote: About to connect LH early style switch housing repro from Z1 ent to main harness of my 78 KZ1000, I am electrically challenged,so by any chance does someone have a photo of how they wired together? Seeing that the wire colors are not the same, it would be a great help.:unsure:
Thanks
Mike
Would examine and compare the wiring diagrams of the two bikes, which may probably be located in the KZr FILEBASE (see top of screen).
Select year, then model, and download the wiring diagram.
Good Fortune! :)
Last edit: 30 Jun 2011 21:53 by Patton.
  • mvent
03 Jul 2011 13:50
#460759
KZ_Rage wrote: Is this the switch you bought (Z1 LH)
Yes that is the one, I have a schematic for the A2A, but it isn't clear to me....at least:angry: No diagrams came with it, that would have been nice however.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
