Dim headlight
  • Blockersrule
  • Blockersrule's Avatar Topic Author
Dim headlight
27 Jun 2011 16:03
#459724
Hey ya'll. I recently purchased a 1982 LTD 550 and the headlight is terrible for riding at night and very dim. What is the best and brightest I can upgrade to without getting too expensive?
  • hocbj23
  • hocbj23's Avatar
Re: Dim headlight
27 Jun 2011 16:10
#459727
Before I replaced the bulb, would ensure that: Battery is in good condition and fully charged,electrical connections to the battery and ground wires are clean and tight,bike is charging as it should, and headlight connections are clean and tight.If all that checks out,then check around for best bulb.Im running an H-4 Sylvania on my bike and it seems to do quite well regards lighting up the road..bj
  • martin_csr
  • martin_csr's Avatar
Re: -
27 Jun 2011 16:24 - 15 Feb 2013 10:48
#459733
Last edit: 15 Feb 2013 10:48 by martin_csr.
  • Motor Head
  • Motor Head's Avatar
Re: Dim headlight
27 Jun 2011 18:45
#459764
Use a volt meter to check, starting at battery posts, voltage along your harness, fuse box, connectors, and switches. Look closely at the Main fuse and wiring going in and out of it. Probably a voltage drop do to resistance along the circuit. You may have low voltage not only at the head light but also your Ignition.
  • MFolks
  • MFolks's Avatar
Re: Dim headlight
27 Jun 2011 18:59
#459772
Cleaning Motorcycle Electrics
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website.
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach.
Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting). I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
The following user(s) said Thank You: Blockersrule
  • bountyhunter
  • bountyhunter's Avatar
Re: Dim headlight
27 Jun 2011 20:27
#459803
Blockersrule wrote: Hey ya'll. I recently purchased a 1982 LTD 550 and the headlight is terrible for riding at night and very dim. What is the best and brightest I can upgrade to without getting too expensive?
Halogen for about $12 that is much brighter than stock. Won't fix electrical problems (if there are any).
www.summitracing.com/parts/WAG-H6024/
