1984 GPZ 1100 Engine Temperature Gauge
- man-of-war
23 Jun 2011 14:26 - 23 Jun 2011 14:41
I was thinking of installing an engine temperature gauge onto my dash on my 1984 GPZ 1100 and was wondering where do I tap into to get the temperature reading?
Thanks,
Thanks,
Last edit: 23 Jun 2011 14:41 by man-of-war.
- Motor Head
Re: 1984 GPZ 1100 Engine Temperature Gauge
23 Jun 2011 17:51
If you buy an aftermarket Temp gauge, it should come with or you will need the correct sending unit for it. The factory Temp sensor for your injection system is just for the computer, not your aftermarket gauge. If the range of the sensor was found to be the same. Hooking it into the factory wiring would require a diode so as to not cause additional resistance to the computer.
Best to have its own separate sensor calibrated for the gauge you buy.
- man-of-war
23 Jun 2011 23:52
I'll be shopping for GAUGES tomorrow, A GAUGE WITH IT'S OWN SEPARATE SENSOR.....BUT WHERE DO I INSTALL THE SENSOR??
- tachrev
- Rubber Side Goes Down
24 Jun 2011 09:27
The 1984 GPZ is still air cooled.
Make sure you are getting a temp gauge and sensor that are for an aircooled engine. The sensor is probably a ring the goes under the spark plug like a washer.
The other option would be a oil temperature sensor.
Build Thread
Build Thread
- man-of-war
24 Jun 2011 12:54
thnks for the heads up tachrev.... If I were to get the
oil temperature sensor where about on the engine would I have to tap into ?
thanks Steve
thanks Steve
- tachrev
24 Jun 2011 13:19
Check out this thread. There is a spot in the oil gallery above the ignition cover.
kzrider.com/forum/2-engine/84155-oil-gal...t=20&tmpl=component&
Build Thread
Build Thread
