Wiring ONLY the ignition coiil
  • wgrothman
  • wgrothman's Avatar Topic Author
22 Jun 2011 18:37
#458775
Hello all,
I am ready to fire up my bike for the first time, however, the wiring is a complete disaster. Before I do a proper wiring job (or buy a new harness) I want to hear the bike run to make sure there are no major issues I am not aware of.
So, can someone explain to me how to wire up JUST the ignition coil. I dont care about switches, lights, horn, kill switch, electric starter, etc. ALL I need is to kick the bike over and hear it start. It is a KZ650 B1 (or maybe B2, hopefully it does not matter).
Thanks.
G
Re: Wiring ONLY the ignition coiil
22 Jun 2011 22:07
#458798
  • wgrothman
22 Jun 2011 22:27
#458803
So, to be clear.
The positive battery terminal connects directly to the positive lead of the coil. (I am running twin KZ750 so its 1 coil).
The negative battery terminal connects to the frame.
The negative terminal of the coil connects to the points and the points connect to the groud (frame).
Is this correct?
22 Jun 2011 22:34
#458805
wgrothman wrote: So, to be clear.
Is this correct?
Is this correct? Yes.
Don't leave it hooked up like this unless the engine is running or while you're attempting to start the engine. It's same as leaving an ignition switch in the ON position.
Good Fortune! :)
  • wgrothman
23 Jun 2011 13:01
#458928
Great. Thanks.
One additial question. How do I ground the points. Is there a wire I connect directly to the frame or is it done simply by the fact that the points are touching the engine already?
The only reason I am askig is because I don't have the bike in frot of me and I will most likely have to describe the process over the phone to a friend.
Thanks,
Adam
