Re: Plugs burning different in pairs
  • calvin17d
  • calvin17d's Avatar Topic Author
10 Jun 2011 02:48
#456460
Update:
Quick check with cheap speery ohm meter.
Infinite primary lead to ground
Infinite secondary lead to ground
secondary coil windings : 14.5K ohms
Resistor style caps 4.6K ohms
1976 Kz900 A4
  • bountyhunter
  • bountyhunter's Avatar
10 Jun 2011 04:10 - 10 Jun 2011 04:12
#456462
Ohm checks on coils are nearly useless because they will only detect a failure that is virtually catastrophic and not common. Old coils break down internally from high voltage arcing across insulation. it only happens with HV applied, not a meter. In many cases it only happens when the coil is hot. I have a rule about coils: if they are old and I am having a spark problem, I throw them away. Z1 sells a cheap EMGO coil that works pretty well. I have run one for about four years now.
If you have decent voltage at the coil and a weak spark, it's probably a hosed coil.
Last edit: 10 Jun 2011 04:12 by bountyhunter.
