charging
- wcrider62
charging
09 Jun 2011 07:12Attachment wcx066.jpg not found
Attachment wcx064.jpg not found
Attachment Copyofwcx075.jpg not found
Attachment wcx122.jpg not found
Ive been to many sights, but so far cant get a clear answere or pic of wires. I have power coming out of stator, all lights staying bright. even the cutting out has stopped. but there doesnt seem to be any power going back to charge battery. yesterday ran great till I stopped at light at idle speed it died and no power in battery to start. had extra battery with just incase. wiring a mess frop earlier owner , bike was recoverd stolen. thinking maybe ther is a wire Ime missing that returns power to charge battery, cant find a wiring diagram that shows or explains what each wire does can any one please help thanks
1982 kz1100 spectre D1
- wireman
Re: charging
09 Jun 2011 08:14
eeeeek,have you got a wiring diagragm? :sick:
The following user(s) said Thank You: wcrider62
Re: charging
09 Jun 2011 08:38
Can I get an order of meatballs to go with that? Seriously, I would look into buying another wiring harness rather than trying to sort out the mess the previous owner(s) made of that wiring. Ed
Re: charging
09 Jun 2011 09:32Looks like a Spectre.
May find a wiring diagram under FILEBASE.
- Motor Head
Re: charging
09 Jun 2011 09:36
650ed has good advice there. Put your Model and year in your signature, then maybe someone has a harness? At least everyone will be able to help better. Maybe a pdf file for a manual or wiring diagram. Also Maybe a link to a used harness.
The bike looks OK otherwise, and changing a harness is easy enough. Then you can look at the other issues from sitting.
- MFolks
Re: charging
09 Jun 2011 15:09
A large wire(maybe 12 gauge) with a white color and red stripe is usually the one going to the battery from the regulator/rectifier. It supplies the charging current.
The regulator/rectifier plug on the 80’s bikes usually has six wires in it:
A. One (1)WHITE with RED stripe, this is the bikes main power wire usually 12 gauge in size.
B. One(1) smaller Brown wire, probably 18 gauge or so, the voltage sense wire for the regulator/rectifier, helps keeping it from overcharging the battery.
C. One(1) BLACK with YELLOW stripe wire, part of the ground circuits, maybe 16 gauge in size.
D. Three(3) YELLOW wires, maybe 14 gauge in size, the alternator output wires going to the regulator/rectifier which converts the Alternating Current(A.C.) to Direct Current(D.C.) using rectification, producing the power to run the motorcycle and charge the battery.
