Clearances/problems with spark? parts?( KZ250A)
  • Sarah Stax
  • Sarah Stax's Avatar Topic Author
05 Jun 2011 04:53 - 05 Jun 2011 05:09
#455523
Hi all
i bought my kz250A about 9 months ago, and rode it round NSW in my school hols. however, its been getting harder and harder to start. One spark plug has great spark while the other is pretty ordinary, does anyone know the points clearances? and the valve clearances?
also, i've only found one place to get parts for the bike in nsw, jos motorcycles, and hes pretty ordinary. Does anyone else know where to get parts from? I'm planning on riding it to Darwin on my ride to England next year- would love some advice on getting her running well again.
thanks!
Sarah :D
Last edit: 05 Jun 2011 05:09 by Sarah Stax.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Clearances/problems with spark? parts?( KZ250A)
05 Jun 2011 09:08
#455544
I dont know the actual specs, but these numbers have worked fine for me.
.003 intake, .004 exhaust (thousands of an inch).
.002 thou for the points gap/dwell - dont bother trying to clean them up, just get new points and condensors.
Clean up your electrical connections with a blast of elec cleaner that restores and protects.
Cheers.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
The following user(s) said Thank You: Sarah Stax
  • Motor Head
  • Motor Head's Avatar
05 Jun 2011 09:53
#455557
I think he meant to say the point gap/ dwell should be .012-.014". .002" the points would barely open, dwell would be like way to long.
the other small KZ owners that have posted in the last week, have had valve adjustment clearances of:
KZ 305= .005" Intake and .008" Exhaust. KZ 400= .008" Intake and Exhaust. I don't have a book for your 250 but somewhere in that range should be fine.
Oh and welcome to KZR.
05 Jun 2011 10:29
#455566
Hi and welcome aboard! The correct point gap is 0.3 to 0.4 mm. The correct valve clearance is 0.14 to 0.19 mm for INLET; 0.21 to 0.26 for EXHAUST. Take a look at the link below and click on "Click here to start download from MediaFire.." It will download a PDF containing the Kawasaki factory shop manual for your bike. Cheers; Ed
www.mediafire.com/?blzzn71mzzj
  • 82KZ305Belt
  • 82KZ305Belt's Avatar
05 Jun 2011 11:22
#455573
Yah....and read my recent thread just a few days ago about the trouble I had with the service manual procedure for setting clearances on my 82 KZ305. Unless you are more savvy than I was about valves (that's not difficult), in which case it can be safely ignored.
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
