Speedo won't work?
- 75Z1-B
Speedo won't work?
03 Jun 2011 21:55 - 03 Jun 2011 21:56
hi all, new to the site but not to bikes.
I have a 75 z1-b 900 and I put new gauges and cables on it. The tach works fine but the speedo is a no go......dumb question but on the cable, does the square end go into the speedo and the round end with the slot go into the assembly????? That is the way I did it but the damn thing won't work. Is there a cog or gear in the speedo that might be broke?????? Or do I have the cable backasswards.
what end goes to the gauge? 1 or 2
Attachment L1010877.jpg not found
ON THE 7th DAY GOD CREATED THE Z1
ON THE 8th DAY I BOUGHT ONE
36 YEARS LATER
IT'S ALIVE
36 YEARS LATER
IT'S ALIVE
Last edit: 03 Jun 2011 21:56 by 75Z1-B.
- etbike3135
Re: Speedo won't work?
03 Jun 2011 22:39
Square end into speedo is correct. Take a hand drill and turn it on reverse and unscrew your cable at the wheel and connect the end of the cable to the drill and run it and then see if the speedo works. If it does PM me and I have the parts you need to fix it.
Tom
Tom
1973 Kawasaki Z1
18 years in dragbikes
