no spark. where to start
  • buddyro
  • buddyro's Avatar Topic Author
06 May 2006 10:05
#45493
Hi. 77 kz1000-A. Just replaced handle bar control pods (with after market pods), fuse box assembly, ignition switch, added front and rear blinkers, replaced reg and rect with a combo unit, fixed a bunch of bad connections, double and triple checked all connections and grounds. Whew! All components work!!
I now have no spark. I checked by laying it on the block and cranking it.
Re-checked all connections and grounds. Manual (Haynes) said I have a bad ignition switch, but its new. I feel like I am missing something very obvious and easy. Where do I start?!?
J
SLO, CA
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: no spark. where to start
06 May 2006 10:51
#45507
Well, I'll give it a stab, though I'm no expert.
To have spark, all you need it constant/stable power to the coil, a working coil/wire/plug, proper connection from the points/ignition to cause the coil to fire, and proper grounding of components.
Check those things. One or more of them is at fault. Unless I missed something....
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • buddyro
06 May 2006 13:03
#45534
Have power at the coil, good ohms across coil and plug wires. How do I check for connection from ignition (Dyna III) other than checking connectors? How do I check for good ground other than connections?
  • buddyro
07 May 2006 10:54
#45675
It is a beautiful day here and I'd love to ride. Somebody please help. :(
All my grounds and ground connections look great. I have power to coils, I have proper resistence through windings (could't get constant reading through secondary but it wanted to read around 20 ohms).
What else can I do?! Could my dyna be bad. The manual says I have a bad ignition switch in this situation, is that possible?
