dead cyl.
- strutt57
dead cyl.
01 Jun 2011 10:27
:huh: 1983 kzltd1100 i have a dead cyl ive changed the coils had the carbs rebiulded and theres 120 on the compression but #2 cyl. is dead there is all kind of spark from the plug im lost help please the season is flying by and im missing it
Re: dead cyl.
01 Jun 2011 11:27strutt57 wrote: :huh: 1983 kzltd1100 i have a dead cyl ive changed the coils had the carbs rebiulded and theres 120 on the compression but #2 cyl. is dead there is all kind of spark from the plug im lost help please the season is flying by and im missing it
Hello, strutt57, and WELCOME to KZr!
If the #2 spark plug tip remains dry immediately after attempting to start the engine, would suspect inadequate cleaning-rebuild job on #2 carb.
Meanwhile, as a diagnostic test, would reverse the plug wire leads between #2 and #3 to see whether the non-combustion issue moves to #3 cylinder.
- kz750saskatoon
Re: dead cyl.
01 Jun 2011 11:49
If problem stays at two, my next step would be to check the carbs. Maybe the fuel level in the bowl is set too low. Or high.
Is the plug wet or dry after trying to start it?
1981 KZ750-H2
Saskatoon, SK
Saskatoon, SK
The following user(s) said Thank You: strutt57
- strutt57
Re: dead cyl.
01 Jun 2011 12:56
the plug is soaked i started it let it run 2 mim and shut it down and it was wet
- strutt57
Re: dead cyl.
01 Jun 2011 13:48strutt57 wrote: 1983 kzltd1100...carbs rebuilt...120 on the compression but #2 cyl. is dead there is all kind of spark from the plug....
Having acceptable compression and good spark, but no combustion, casts more suspicion toward the carb, and the wet plug indicates an excessively rich mixture for whatever reason.
- strutt57
Re: dead cyl.
01 Jun 2011 14:06
the funny thing is that last year it ran real good then all of suddon this starts
Re: dead cyl.
01 Jun 2011 14:08 - 01 Jun 2011 14:09
Would remove #2 spark plug; spray starter fluid into the plug hole to help de-flood the cylinder; use compressed air, if available, to blow out the cylinder; install a brand new NGKB8ES spark plug; and try again.
Past experience has been that a flooded plug that sparks when tested outside the cylinder may nevertheless fail to fire when installed, even a relatively new plug.
Last edit: 01 Jun 2011 14:09 by Patton.
- MFolks
Re: dead cyl.
01 Jun 2011 15:35
Try if possible a Denso W24-ESU sparkplug, as I've lost any trust of the NGK's made in the U.S. If you can find NGK's made in Japan, use them. I've had new NGK's fail right out of the box more than once.
