Blew Main Fuse
- Jay650
Blew Main Fuse
01 Jun 2011 09:24
okay so i was driving along yesterday, and my bike just shut down, no power at all to anything. pulled over and sat there for a minute trying to figure out what had just happen. checked fuse box, and found the main fuse was blown. luckily there was a hardware store not far from there, walked up got a couple fuses and put on in, bike started right back up and i ran it the rest of the day, put a little over 100 miles on it. any ideas on what could have caused this. wires look to be okay, could it possibly have just been an old fuse? the bike is an 81 650
- Motor Head
Re: Blew Main Fuse
01 Jun 2011 09:48
Heat/ resistance from dirty/ loose fuse clips. Dirty connections in harness connectors, high resistance. Possibly an intermittent short where a wire has rubbed through.
Or just an old fuse that was weakened from years of service.
- MFolks
Re: Blew Main Fuse
01 Jun 2011 15:27
I replace my glass tubed fuses every year as current surges,& vibration can quickly cause these fuses to fail. More than a few riders have changed to the newer car type fuses with the blade style fuse.
Fuse And Fuse Holder Designations
1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1” long. Most good auto parts stores can get them for you. They are ¼” in diameter.
2. The more common AGC is 1 ¼” long and may not fit the smaller fuse clips. Again, ¼” in diameter.
3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
4. These fuses can fail internally but look good, only by removing them from the clip and electrically continuity checking with either a self powered test light, or a multimeter set on OHMS can they be determined to be in good shape.
5. A physical inspection of the metal end caps for tightness will tell you if the fuse is serviceable.
6. Most modern motorcycles are now using the automobile “Blade” style fuse with the designation of ATC or ATO.
7. The reduced sized “Mini” Blade style fuse holder uses the ATM size of fuses.
8. If the fuse and fuse holder overheat, it could soften or anneal the grip of the clip, it might require squeezing the clip to restore the tightness.
9. A list of where to purchase “Blade” style fuses and holders:
www.waytekwire.com order.waytekwire.com/productdetail2/M50/...20%20%20%208%20FUSE/
www.rallylights.com www.rallylights.com/detail.aspx?ID=765
www.delcity.net/store/6!way-fuse-blocks/p_10822.a_1
10. A source for the glass tubed AGX fuses:
www.boatownerswarehouse.com/browse.cfm/2,4986.html
