Where are there wires supposed to go (uh-oh!)?
  • slick94prix
  • slick94prix's Avatar Topic Author
29 May 2011 23:05
#454261
As mentioned in a thread I created in another section, just picked up this bike.
There are a few wires that are not connected up. I followed the wiring diagram in the manual, but I couldn't quite figure it out.
Picture number one: On the rear fender, in front of the taillamp. Wire colors are Green, Black/White or Black/Yellow, and Grey.
Picture number two. These are right beside the battery on the negative terminal side. Colors are Yellow/Black and White/Blue.
  • 2wheeladdict
  • 2wheeladdict's Avatar
Re: Where are there wires supposed to go (uh-oh!)?
29 May 2011 23:13
#454262
If I am not mistaken these wires in the first pic are for the turn signals. Are your signals on the bike? The black/yellow is the ground that is why it has a double pin connection, one for each signal. I am not sure which of the others is left or right +. check with a test light or meter. Someone correct me if i am wrong.
80 KZ1000 LTD
81 Yamaha XJ650 maxim
84 CR60r
  • slick94prix
29 May 2011 23:16 - 29 May 2011 23:19
#454264
Probably missing rear turn signals. I think they are supposed to be mounted behind the rear shock/spring assembly's. If that is the case, yes mine are missing.
My taillamp housing is in poor shape as well (I'm sure that the Texas sticker that is on it probably indicates that it has seen some sun in its earlier life). I'll probably just pick up a taillamp/turn signal housing combo.
EDIT: You were absolutely correct. Tested with my DMM right quick, and it verified that they are the turn signal wires for the rear.
Last edit: 29 May 2011 23:19 by slick94prix.
  • MFolks
  • MFolks's Avatar
29 May 2011 23:54
#454275
Color Codes On Most Kawasaki’s
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb.
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb.
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb.
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb.
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb.
GREY, Right rear turn signal circuit.
  • slick94prix
30 May 2011 21:00
#454400
Anyone have any ides on the 2nd image?
  • MFolks
  • MFolks's Avatar
30 May 2011 22:04
#454412
Some bikes have provisions for heated vests and grips. Trace back and see if there is a fuse(s) holder these wires go to. The Black wire with the yellow stripe is part of the ground circuit.
  • xdrugfreejonnyx
  • xdrugfreejonnyx's Avatar
31 May 2011 13:24
#454509
The 2nd pic could be an accessory lead. If you look at a wiring diagram for the bike it should show the - and + accessory leads.. and if you can find them you might be able to trace it back.
  • JakeB
  • JakeB's Avatar
31 May 2011 16:15 - 31 May 2011 16:23
#454545
xdrugfreejonnyx wrote: The 2nd pic could be an accessory lead. If you look at a wiring diagram for the bike it should show the - and + accessory leads.. and if you can find them you might be able to trace it back.
You got it, the wiring diagram shows two sets of accessory leads yellow/black (-) & white/black (+), and yellow/black (-) & white/blue (+). These are both un-switched on separate 10 amp fuses.
kzrider.com/filebase/cat_view/102-1982/181-kawasaki-kz-650-h2
edit: should be black/yellow on the negative leads
1978 Z1-R
Last edit: 31 May 2011 16:23 by JakeB.
  • slick94prix
01 Jun 2011 18:37
#454824
Great! Thanks all.
I'll trace them back.
