new turn signals killed all turn signals...y?
- bbirch
23 May 2011 02:14 - 23 May 2011 02:17
o.k. so I just put on these new led strip lights for my rear turn signal lights and they worked a few times and now I don't have any turn signals at all,(front or rear) I am confused, can any one help plaese.:pinch: :dry:
Last edit: 23 May 2011 02:17 by bbirch. Reason: misspelled words
- anyday
Re: new turn signals killed all turn signals...y?
02 Jun 2011 02:42
First place I'd check is the 10 amp "Flasher" fuse.
1981 KZ 1000-k, 1982 GS300L-D, 1982 GS300L-Z (parts)
Sioux City, IA
Sioux City, IA
- btchalice
02 Jun 2011 23:14
no lights at all or just not flashing?
you might need the electronic flasher relay because led lights dont put enough load on stock ones
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- tachrev
- Rubber Side Goes Down
03 Jun 2011 09:23btchalice wrote: no lights at all or just not flashing?
This is it. If you switch to LED turn signals, you need a different flasher.
Build Thread
Build Thread
- Lifted94XLT
23 Jun 2011 14:21tachrev wrote:btchalice wrote: no lights at all or just not flashing?
Do you just need a Heavy Duty Flasher that you can buy from the parts store or do you need something special?? I just installed LED rear taillights on my bike (removed the fronts) and I'm having the same problem, they burn steady with no flash. Thanks and sorry for the hijack
- MFolks
23 Jun 2011 15:35
