dyna ignition
- murr50
dyna ignition
21 May 2011 20:07
The other day i went to check the ignition timing of my bike. (The ignition was already installed when i made the purchase.) So i hooked up a volt meter to the black ignition wire and to a ground and advanced the engine to the f mark for 1,4. (is this correct?)The volt meter only read 9.6 volts. The instructions state that it should read 12. So i loosened the ignition plate anbd moved it around a bit, but the voltage never really changed.... Im clearly confused, could anyone be of assistance? thanks
1977 kz650 C
- wireman
Re: dyna ignition
21 May 2011 20:18
the ignition plate has nothing to do with voltage going to it,thats for advancing/retarding your timing.
check voltage to your coils with a meterto make sure you have 12v
- murr50
Re: dyna ignition
21 May 2011 20:21
the voltage at my coils is currently 9.6...
1977 kz650 C
- wireman
Re: dyna ignition
21 May 2011 20:24
start back at your battery and make sure its charged to 12v.then go through your electrical connections to make sure nothing is loose or dirty causing a voltage drop.
- murr50
- wireman
Re: dyna ignition
21 May 2011 20:27
- MFolks
Re: dyna ignition
21 May 2011 20:32
Fully charge the battery, and then see if you have at least 12 volts at the battery. 14.5 would be better,now see if you have the same voltage at the ignition coils, if not, then it's time to do some:
Cleaning Motorcycle Electrics
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website.
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach.
Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting).
I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
- lemo32
- The Price of Cool aint cheap
Re: dyna ignition
22 May 2011 00:08
These units can ground through the mounting plate, causing low voltage to coils, leave your ignition on for longer than 5 minutes and you will get to find out first hand what junk dyna sells, electricity follows the path of least resistence.
1979 kz 1000 06 katana 750
