Swaped rear directionals, now nothing
  • Jay650
  • Jay650's Avatar Topic Author
19 May 2011 20:41
#452214
Attachment lights2.JPG not found
Attachment lights.JPG not found
okay so i put on a new set of rear directionals on my 81 kz650. i mounted them on the tail light housing so that i can make room for new saddle bags that are comming. everything is all hooked up but they will not flash, and now the front directionals just stay lit up. the directionals i put on the rear are the match to the ones on the front which have been on for a couple months and working fine. anyone have any ideas. im sure im am just missing something simple.
  • MFolks
  • MFolks's Avatar
Re: Swaped rear directionals, now nothing
19 May 2011 20:51
#452217
You should check with the local law enforcement people before using amber lights in the rear for running lights. I believe Federal law prohibits amber at the rear except for directional operation(turn signals).
As for your problem, I suspect a ground wire is not hooked up.
Color Codes On Most Kawasaki’s
HEADLIGHT:
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT:
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL:
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL:
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL:
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL:
GREY, Right rear turn signal circuit.
  • Jay650
19 May 2011 20:58
#452218
they are the directionals, all i did was remove the factory ones, and put on these, did them one at a time, took the wire from then original left rear directional and put it on the new left rear directional, then the same for the right. i didnt really change any wireing. thats what has me stumped
  • Motor Head
  • Motor Head's Avatar
19 May 2011 21:33
#452220
Try grounding the stem of your signal to the frame. Yellow in the rear? No.
  • Jay650
20 May 2011 10:31
#452353
okay i got them working, grounding the stem worked. but im confused on the whole no yellow in the rear. the stock ones were the same color. i didnt set them up as running lights or brake lights. just directional. so yellow should be okay right?? i looked at some pictures of other kz's and most of them have yellow directionals too. im bringing the bike in for state inspection next week so if this isnt correct then i want to change it before i go in
  • Motor Head
20 May 2011 11:03
#452355
Sorry about that, I am confused with reflectors. Both my KZ's have yellow on all 4 corners.
  • Jay650
20 May 2011 11:11
#452357
okay cool. this is my first bike, so i wasnt sure if maybe someone had changed then im the past. atleast i know it is okay now. thank you
20 May 2011 13:28
#452393
Did you check the bulbs to make sure they're the same type as the originals? If, for example, they're LED bulbs they won't flash with the original flasher. Ed
