Wiring Diagram
- badrhino
Wiring Diagram
10 May 2011 13:04
Where can I find a wiring diagram? This bike (1980 KZ1000 LTD but with J model motor) looks like it has been rigged all over so kinda need to know what goes where, maybe I can figure it out by reverse engineering.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- loudhvx
Re: Wiring Diagram
10 May 2011 14:07
In the upper right corner there is a link called "filebase". Click on that and look for the year then model. There may be a diagram already posted there.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- MFolks
Re: Wiring Diagram
10 May 2011 16:19
Here's the newer engine and bike wiring diagram, it covers 1981-1982 Kz1000/Kz1100's:
www.kawiworld.com/index.php?option=com_c...icle&id=77&Itemid=99
It's a shop manual, so just about everything is listed for the "J" engine.
- badrhino
Re: Wiring Diagram
10 May 2011 20:55
Sweet. Thanks guys!
Franken Z!
Franken Z!
