Fuse pops when start button is pressed
- Omaha Rider
08 May 2011 17:31
Ok, so I have a short somewhere in my starting mechanism because all of my lights work, but when my starter button is pressed the main fuse pops. Could someone tell me what I should test with a multi-meter to find this short? I looked up the wiring diagram on kz650.info but it makes no sense to me. Too much shit going everywhere. Thanks in advance guys
1978 KZ650 SR D
- Nebr_Rex
Re: Fuse pops when start button is pressed
08 May 2011 17:51
Pinched wire some where between the battery to the ign. switch to the starter button to the starter relay switch.......?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- TeK9iNe
- What did you do!?!
08 May 2011 18:14
Look in the filebase here for a copy of your wiring diagram, or something close enough.
You will probly want to purchase some decent wire wrap to re-do your harness, cause your gonna be tearin it apart!
Trace all the wiring and compare every connection to the diagram. Clean everyconnector thouroughly by taking them apart and sanding/filing, and use a good electrical connector spray that protects them before re-assembly.
Good luck!
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Motor Head
08 May 2011 20:47
Since the fuse blows when starter button is pushed, I would disconnect the solenoid first, then retry. Could be a faulty solenoid. If it still blows then check inside the head light housing, and under the tank for a short. Your bike doesn't have wires running through the bars for the switches does it? If so this would be a common place for a short.
- Omaha Rider
11 May 2011 12:27
Found a cut open wire coming straight off the starter button inside the handle bars. Shrink wrapped and e taped it up and the bike is running agian. Thanks for the replies
1978 KZ650 SR D
- Motor Head
11 May 2011 13:28
Good to here, an easy and cheap fix.
