1981 kz 1000 kill switch
  • dealer21
  • dealer21's Avatar Topic Author
08 May 2011 16:49
#449651
Recently purchased a 1981 kz1000 csr for my son. Ran fine when purchased, sat in garage for one month untill graduation and now I cant get it to start. Turns over good but acts like no spark at all. I think little hands may have been on the bike, my question is besides the start/kill switch on the right side handlebar, there is a small red rocker switch on the left handlebar that is not the horn, high beam or turn signel, could this be a seperate kill switch, if not what is its function. Thanks,
Re: 1981 kz 1000 kill switch
08 May 2011 17:33 - 08 May 2011 17:35
#449663
dealer21 wrote: ...1981 kz1000 csr...small red rocker switch on the left handlebar that is not the horn, high beam or turn signal, could this be a separate kill switch, if not what is its function. Thanks,
Until better help comes along, will guess that it might be a switch for hazard blinkers or to cancel an automatic turn signal shut-off.
Pretty sure it's not another kill switch.
Good Fortune! :)
Last edit: 08 May 2011 17:35 by Patton.
The following user(s) said Thank You: dealer21
  • MFolks
  • MFolks's Avatar
08 May 2011 19:05
#449676
The red rocker switch turns on the 4 way flashers(2 front,2 back). Check for spark by using these:
Ignition Systems Testers
www.lislecorp.com/divisions/products/?pr...ivision=1&category=8
If no spark, see if the ignition coils are getting battery voltage to the red terminals(this comes from the run/stop switch on the right handlebar switch pod).
