What is this?
- Omaha Rider
What is this?
07 May 2011 03:10
I have no power to my bike at the moment and im wondering what this thing in the middle is. The positive battery terminal goes straight to it. Is it the starter relay? Can these go bad and cause complete loss of power? Thanks
1978 KZ650 SR D
- Proxy
- 80% Human 20% Nuts/Bolts
Re: What is this?
07 May 2011 09:36
Yep it's the starter solenoid. But when you say no power. Do you mean no lights, horn or anything? If so check your main fuse. Even if it does not look blown it could be bad. Had a few like that especially with glass fuses. Good luck
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- otakar
Re: What is this?
07 May 2011 09:43
Answer the first question Yes, second question No. Check your fuses first and than your ignition switch and plugs.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
Re: What is this?
07 May 2011 09:53
Unlikely but it is a COIL after all and yes it can happen where you have a shorted winding(s) in the solenoid input coil...
As mentioned check fuses no doubt, in reference to battery ground(frame), measure voltages from battery through terminal connections into ignition switch. Turn ignition switch and measure output voltages.
Same time you can disconnect the (+) feed to the solenoid, and confirm power being supplied throughout your electrical system.
Confirm ideal grounding to frame, engine case...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Omaha Rider
Re: What is this?
07 May 2011 12:42Old Man Rock wrote: Unlikely but it is a COIL after all and yes it can happen where you have a shorted winding(s) in the solenoid input coil...
OMR
When you say disconnect the positive feed to the solenoid and confirm power throughout my electrical system, what does that mean. How do I confirm the power?
1978 KZ650 SR D
Re: What is this?
07 May 2011 13:02
Please post a picture of the positive battery cable where it attaches to the battery. Ed
- MFolks
Re: What is this?
07 May 2011 16:23
For safety reasons, when working around any battery powered vehicle. I always disconnect the Negative post on the battery. This way, if the Positive cable touched any frame parts, there would not be any sparks,flames or arc welding simulations.
The starter solenoid carries the high current(amps) to be able to rotate the starter motor, starting the engine. The start button on the right handlebar pod connects to the coil wires of the solenoid when pushed. This switch could not carry the load and would quickly burn out.
