1978 KZ650 Chopper Wiring?
  • FrankySwarm
  • FrankySwarm's Avatar Topic Author
29 Apr 2011 14:16
#447719
Does anyone have a simple wiring diagram for a 1978 KZ650 (just the minimum, such as taillight and headlight, etc.) I figured since i fired all my other wiring I might as well just do em over bare bones ! Thanks in advance.
  • Motor Head
  • Motor Head's Avatar
Re: 1978 KZ650 Chopper Wiring?
01 May 2011 01:22
#447947
This is the thread you want, kzrider.com/forum/4-electrical/172746-19...bones-for-mattylight
Member Loudhvx has done several Bare Bones wiring for others in this thread. Have a look and the info should be there for you. :)
  • Old Man Rock
  • Old Man Rock's Avatar
01 May 2011 12:15 - 01 May 2011 12:48
#448014
Edited: removed wrong year/model
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 01 May 2011 12:48 by Old Man Rock.
  • loudhvx
  • loudhvx's Avatar
01 May 2011 12:41 - 01 May 2011 12:47
#448021
Old Man Rock wrote: This what you're looking for?
Now this drawing doesn't include lighting/break lights etc... Tap off the ignition switch brown conductor through a toggle switch and tie in your lighting system... Can't get any simpler then that.
Attachment not found
I believe that is for a 77 KZ650. The 78 uses a single-phase permanent magnet alternator. If his is a very late 77 sold in 78, that diagram might work.
Also, check out the starter button/relay wiring. You deleted the black wire from button to relay such that it looks like you are running the black wire to the white hot wire (thus bypassing the ignition switch completely), and at the relay it looks like the start wire is connected to the ground of the battery.
I think you just need to re-draw that black wire, and draw the battery ground from battery to rectifier.
Last edit: 01 May 2011 12:47 by loudhvx.
  • Old Man Rock
01 May 2011 12:47
#448025
Good point Loud... Wasn't meaning exact model number but more on how to simplify his wiring.
My bad, I'll remove...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • loudhvx
  • loudhvx's Avatar
01 May 2011 12:50
#448026
I didn't realize you were still online. I edited the post because you may want to make a couple fixes on that diagram.
  • FrankySwarm
02 May 2011 12:55
#448262
Thanks for the help guys, i am gonna start making the harness next week so ill do a project thread and show you guys wea I am at!
