one wire signals
  • indianajames
  • indianajames's Avatar Topic Author
one wire signals
29 Apr 2011 06:26
#447676
put some new signals on,now they won't blink . one wire design , grounded to frame , hot to lead. do they have to be isolated from frame ? 82 750 ltd
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
Re: one wire signals
29 Apr 2011 08:50
#447681
I had a set of those too, and they didn't work either. I made sure my ground from the battery was good, and made sure the signal stem was well seated to the frame, no dice. I jsut got another set...you could always just throw a ground lead on there too.
  • Motor Head
  • Motor Head's Avatar
29 Apr 2011 10:04
#447690
You didn't say what signals you have, please state the type of bulb in the signals. LED will require a different flasher, and resistors to load the circuit. There are threads on LED signals.
  • indianajames
29 Apr 2011 18:04
#447746
turns out these suckers are such small bulbs i thought there wasn't enough resistance as with led types so i added another signal next to each one . still no blink blink . gonna try an inline resitor next . if it works i will post pictures . these are really accent running lights , but i figured when these burn out i will put led inside housings .
  • gumby prichard
  • gumby prichard's Avatar
03 May 2011 03:34
#448490
I have a 78 kz400 b1 and i bought some LED turn signals that have two wires for each...black and read. Im guessing positive and negative....now when i took my stock turn signals off they worked...i put the leds on...nothing, then i plugged the stocks up and now....nothing......what do i need to get these leds working on my bike...if i plug the negative into the ground wires instead of the wires the normal signals use to complete the circuit, then they just all come on either way i turn the signals on. PLEASE HELP! thanks!!
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • otakar
  • otakar's Avatar
03 May 2011 08:33
#448501
a single wire signal requires a grounding loop. I believe that most signal stems are rubber mounted. Notice the grommets in the top right.
www.z1enterprises.com/images/parts/DSC02695.jpg
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
The following user(s) said Thank You: indianajames
  • gumby prichard
03 May 2011 21:11
#448637
still no help :/
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • indianajames
03 May 2011 23:21
#448666
otakar , turns out you are right . i tried every thing . then i got to looking at the old stems and thought the rubber was for vibration , but then i realised it also isolated the ground from the frame . the signals ground wire was also black with yellow stripe , different than others , plus it didn't just go to frame ,it ran into the harness . so i came to share my findings and you allready gave me the answer . thanks for the affirmation though.
  • otakar
  • otakar's Avatar
04 May 2011 10:49
#448784
Glad to be of help. Most of these bikes had grommet inserts to ground the signal stem. If you take a look at the picture in the Z1E link you will see those in the two grommets in the top right. They have the grounding wire attached to them.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
