Ignition shot?
- cincykz
Ignition shot?
27 Apr 2011 10:23
Hey all,
The bike is gone through, carbs done and set right, new coils wires plugs, new filters fluids header, runs like a dream. Until... it switches to two cylinders. I know that it's not the coil, it's brand new and if I switch the ignition wire the problem jumps to the other coil. The wires are all good. The ignition is some sort of electronic, not a dyna, not a kawasaki. The bike is a 79 650b3. Im about ready to order a new dyna s, any thoughts before I do?
- MFolks
Re: Ignition shot?
27 Apr 2011 15:53
Pictures? Maybe we can help if it's identity is known.
- bountyhunter
Re: Ignition shot?
27 Apr 2011 17:18
Sounds like it has to be either the mag pickup or the igniter failing at temp.
- cincykz
- MFolks
Re: Ignition shot?
28 Apr 2011 15:51
Ohm Checking Pickup(Pulsing) Coils
The pickup coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of 2K, check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS. The 550’s,650’s & 750’s may be backwards to the Z1’s,Kz900’s,Kz1000’s & Kz1100’s.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S” electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6. Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
7.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
- Grantl
- KZRider is Da Bomb!!!
Re: Ignition shot?
23 May 2011 13:49
Mfolks,
thanks again for the tip. My KZ1000 M1 has been doing this recently (runs on 4 then, when warm will switch to 2), I will do the recommended checks of the pickup coils and proceed as necessary.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
1990 550 Zephyr
1994 KZ1000 P
- MFolks
Re: Ignition shot?
23 May 2011 16:22
Pick up(pulsing coils) can fail like any other part of the ignition system. I'd do ohm checks cold and hot to see if they are failing.
