Dyna 2000 Ignition advance
- 771000KZ
27 Apr 2011 09:03 #447309
by 771000KZ
Dyna 2000 Ignition advance was created by 771000KZ
I installed this and set the timimg static @ 30 degrees. The bike starts, revs and idles fine. I got a timing light and now want to set it correctly but I have looked everywhere and can't find the degrees advance it is supposed to be? All I can find is in reference to the T marks on stockers. The dyna has a degree range.
I think it should be about 35 degrees but I'm not 100% sure. Anyone know?
- testarossa
- Thank you received: 82
27 Apr 2011 09:13 #447310
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic Dyna 2000 Ignition advance
I can't remember off the top of my head, but I should have the info when I get home this evening. Seems to me that the Dyna installation instructions had information about total advance and which advance curve to select on a chart. I'm certain that I took the info from them.
2004 ZX-10R
Angola, IN
- Motor Head
- Thank you received: 391
27 Apr 2011 09:42 - 27 Apr 2011 09:43 #447314
by Motor Head
Replied by Motor Head on topic Dyna 2000 Ignition advance
This is a link to the Dyna site instructions, you may have it already.
www.powercommander.com/downloads/Support...s/DDK1-5_2-1_3-2.pdf
Last edit: 27 Apr 2011 09:43 by Motor Head.
- testarossa
27 Apr 2011 10:15 #447319
by testarossa
2004 ZX-10R
Angola, IN
Thanks Motorhead. 77KZ1000 Look on page 7. You probably want advance curve #4 and total advance of 40* at 3500 rpm.
2004 ZX-10R
Angola, IN
- 771000KZ
27 Apr 2011 10:19 #447321
by 771000KZ
Replied by 771000KZ on topic Dyna 2000 Ignition advance
ok, so I'm clear. I set the static timing to 40 degrees which is what it will be at full advance? Looking at the graph if I shoot my timing light at it at idle it should be showing about 20 degrees. I think that is where I was confused as I that that by setting it static @ 40 degrees I would be @ 65 degrees total timing at full advance.
Thanks for clarifying guys.
- testarossa
27 Apr 2011 10:26 #447324
by testarossa
2004 ZX-10R
Angola, IN
Yeah, what you set at static timing will be full advance. So set the static to 40 and then verify that 1/4 and 2/3 are reaching 40 at 3500 rpm with your timing light.
2004 ZX-10R
Angola, IN
- Motor Head
28 Apr 2011 10:27 #447525
by Motor Head
You really should have either a timing light with built in advance wheel/ digital functions, or a degree wheel to make additional timing marks. Setting the 2 pick-up coils the same, so you will have the correct advance on all 4cyl is the best place to start. You may have to do that before setting the total advance up.
- mark1122
- Keep twisting it
- Thank you received: 109
29 Apr 2011 15:34 #447727
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Dyna 2000 Ignition advance
40 is a good place to start. if u are in good tune u may get down to 38*
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
