Help me id this electrical part?
  • purls
  • purls's Avatar Topic Author
26 Apr 2011 19:23
#447217
Attachment weed036.jpg not found
It's in the battery compartment. The wire on the right is disconnected, and there's a disconnected frame ground nearby, but the connectors do not connect as is. The connectors on both the frame ground and the mystery component are female - they're both double connectors, post connector is the correct term, I think.
Also, should disconnecting my taillight and rear signals affect the operation of my front signals?
And lastly, where's a convenient place to tap into switched 12 volt for my dyna pickup? And what does the term "switched" refer to?
Thanks in advance,
purls
1983 KZ750 Spectre
1978 KZ650B2A
  • wireman
  • wireman's Avatar
Re: Help me id this electrical part?
26 Apr 2011 19:25
#447218
switched means its not constantly hot B)
  • MFolks
  • MFolks's Avatar
26 Apr 2011 19:59
#447222
Some of the bigger kawasaki's have/had provisions for aux electrical power for gloves and vests. They had their own fused power taps.
  • purls
26 Apr 2011 20:32 - 26 Apr 2011 21:05
#447227
Assuming this is actually a power tap, and I can get my tester to light, couldn't this be a good choice for my coil voltage tap?
EDIT: mystery part is an accessory fuser. Thanks mfolks.
1983 KZ750 Spectre
1978 KZ650B2A
Last edit: 26 Apr 2011 21:05 by purls.
