Instrument lamp holders
  • TomW
  • TomW's Avatar Topic Author
  • Keep the blue side up.
17 Apr 2011 17:43
#445153
Anyone here have an idea for replacing the rubber lamp holders inside the tach and speedo? Mine dried out and crumbled when I pulled them to replace the lamps last year. I got by then, now they're toast. A new instrument harness costs $140.:ohmy: Yeah right! So I need some ideas or some used parts.
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
  • z1kzonly
  • z1kzonly's Avatar
Re: Instrument lamp holders
17 Apr 2011 18:38
#445157
Light bulb socket holders?
Or the foam that lays on the aluminum bracket?
You can always improvise!
  • TomW
18 Apr 2011 02:11
#445266
It's a molded rubber cover over the sockets. They poke through the back of the meter and are removable to replace the bulbs. I was hoping some one had a source for a commercial part that might work. I will improvise some way. Maybe turn some bushings from nylon bar stock. I was hoping for an off the shelf answer.
No foam in my meters.
  • MFolks
  • MFolks's Avatar
18 Apr 2011 02:20
#445269
Are your bulb sockets the older insert and twist type or the baseless type that take #168 or #194 bulbs?
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
18 Apr 2011 07:01
#445279
I bought mine from Z1E
Call Chris @ Z1E, he located some new ones for me.I replaced all of mine I even used one of the ones he found for me on the "Brake" bulb indicator lite on Tach Gauge which is supposed to be no longer available.
Regards
ED
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
  • TomW
19 Apr 2011 01:09
#445450
MFolks wrote: Are your bulb sockets the older insert and twist type or the baseless type that take #168 or #194 bulbs?
Bayonet bulbs. I think they are 1194's.
  • TomW
19 Apr 2011 01:10
#445451
ed spangler wrote: I bought mine from Z1E
Regards
ED
Thanks Ed, I'll call in the AM.
