Electric start wont work and not getting any spark
  • jbrewer73
  • jbrewer73's Avatar Topic Author
15 Apr 2011 14:39
#444770
I just got a 1992 kawasaki ninja 500 that sat for about a year. Supposedly it ran fine befor parked, but who knows it was given to me for some money that was owed. I turn the key on and have power, lights, turn signals, horn. But i turn the switch to "run: and no electric start. I jump the solenoid and it is cranking over but no spark at all. Any ideas where I can begin on this. The coils seem to be fairly new. I have inly had old 900 or 1000cc kaws so these newer ones are brand new to me. I was looking for th ignition but all i see is the coils that route into the loom and then to an igniter.
Any ideas would be appreciated
Thanks
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Electric start wont work and not getting any spark
15 Apr 2011 17:57
#444795
Check to see if there is voltage to the coils, should be near battery voltage with key on.
Check fuses FIRST, of course.
Diagnostic/maintenece is still fairly close to the old zeds. Pull and check/clean as many connectors as you can get at (hopefully all of em').
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • TexasKZ
  • TexasKZ's Avatar
  • Away
16 Apr 2011 21:04
#445027
I believe that bike has both the side stand and clutch lever cutout switches. Be sure they are functioning properly.
