Battery chargers
- mark1122
- Keep twisting it
Battery chargers
13 Apr 2011 12:11
this is for all u electrical gurus out there.
i hear that batteries for our bikes should be charged with trickle chargers that are less than 1 amp.
true or false ?
i see chargers at .9ma and others at 1.5 or even 2 amps from battery manufactures such as Yuasa. whats up ? which 1 do i need? will my 2 amp charger do any harm?
i read that your bat will last longer if it is kept up to charge between rides .
My kz or cbr can sit for a few weeks between rides, sometimes longer.
true or false ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Motor Head
Re: Battery chargers
13 Apr 2011 12:33
Hard to beat the Float Charger from HF/ China Tools.
www.harborfreight.com/catalogsearch/result?q=float+charger
I've got a current coupon for $4.99, they work really good. I keep my batteries on this charger when not in use, all winter.
- bountyhunter
13 Apr 2011 16:31 - 13 Apr 2011 16:31
The "2A" rating refers to max current. Good chargers use what is called "CC/CV" which means constant current/constant voltage method. When the battery is low, the charger pumps in the maximum current (constant current). When the battery reaches the correct voltage, it tapers off the current to hold that voltage (constant voltage mode). For bike batteries, a 2A max should be OK since most are in the 10-15A-hr ballpark. What's important is that the trickle chrger will charge to the correct voltage and hold it there, and that it has the proper temperature compensation on the set point voltage to match the battery.
Last edit: 13 Apr 2011 16:31 by bountyhunter.
- andy9802gt
- If it tastes that good, eat it yourself.
13 Apr 2011 17:19
I just bought a C-TEK charger for mine from the bike shop for @$40. It hardwires onto the battery and has a pigtail that you can hide under the seat. The guys said it was better than the battery tenders that they had right next to them and so far I can't say they're wrong. I got the cheaper of the two versions they had on hand, the other one would even charge deep cycle marine batteries, which means you could buy another pigtail for it and just swap the charger from toy to toy, you should check them out.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- mark1122
- Keep twisting it
13 Apr 2011 17:46bountyhunter wrote: The "2A" rating refers to max current. Good chargers use what is called "CC/CV" which means constant current/constant voltage method. When the battery is low, the charger pumps in the maximum current (constant current). When the battery reaches the correct voltage, it tapers off the current to hold that voltage (constant voltage mode). For bike batteries, a 2A max should be OK since most are in the 10-15A-hr ballpark. What's important is that the trickle chrger will charge to the correct voltage and hold it there, and that it has the proper temperature compensation on the set point voltage to match the battery.
I am wondering why some are .9ma and some are 1.5amp,some are 2 amp.
the local dealer said i should have less than 1 amp for bike batteries??
is that false ?
Yuasa has a .9ma a 1.5 amp.and a 4 amp.
www.yuasabatteries.com/pdfs/2011_yuasa_apps_specs.pdf
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bountyhunter
13 Apr 2011 20:25
It depends on the design of the charger. If it is smart enough to taper off and hold the correct voltage, I think 2A is safe because it won't be at that value for long. If it's a "dumb" charger that just trickles current into the battery continuously, you don't want to use it.
Check the internet for info on the charger before buying. A dumb charger will boil the water out of the battery. A smart charger will not.
- jjack010
13 Apr 2011 22:22
I use a 2A charger with no problems.
1974 Kawasaki Z1
Central Texas
Central Texas
- RonKZ650
14 Apr 2011 00:44
No doubt every charger is different. I have a 1.25A Battery Tender that is generally regarded as a great safe charger. I have like 8 motorcycles give or take I rarely ride and for years I would use this charger once a month for 24 hours on each battery all of which are stored indoors. The result was all 8 batteries would be bad whithin 2 or 3 yrs, so I was basically riding around 50 miles on each battery before it crapped. I came to the realization that either I was overcharging or the battery tender was just a waste of time and effort to use, so I got the pulse tech extreme battery charger and use it instead, but only once every 6 months or so and all the batteries were purchased 11 years ago and still fine, so my take is don't overcharge.
- dejavoodo41
14 Apr 2011 00:58
I have a 1.5 amp Schumacher from Walmart it cost around $20 and works great. It has a float mode and has the pigtail so it can be wired straight to the battery. I don't use the pigtails since my bike usually never sits for more than a couple days here in FL but I have a battery on it for a few weeks and the battery was ready to go when I needed it
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- bountyhunter
14 Apr 2011 02:34A properly designed charger can't overcharge. If it is doing what you describe, it's either not intended for continuous (float charge) or it's just a piece of junk. I have had my charger attached to my battery steady for about 15 years.RonKZ650 wrote: No doubt every charger is different. I have a 1.25A Battery Tender that is generally regarded as a great safe charger. I have like 8 motorcycles give or take I rarely ride and for years I would use this charger once a month for 24 hours on each battery all of which are stored indoors. The result was all 8 batteries would be bad whithin 2 or 3 yrs, so I was basically riding around 50 miles on each battery before it crapped. I came to the realization that either I was overcharging or the battery tender was just a waste of time and effort to use, so I got the pulse tech extreme battery charger and use it instead, but only once every 6 months or so and all the batteries were purchased 11 years ago and still fine, so my take is don't overcharge.
- mark1122
- Keep twisting it
14 Apr 2011 10:45bountyhunter wrote:A properly designed charger can't overcharge. If it is doing what you describe, it's either not intended for continuous (float charge) or it's just a piece of junk. I have had my charger attached to my battery steady for about 15 years.RonKZ650 wrote: No doubt every charger is different. I have a 1.25A Battery Tender that is generally regarded as a great safe charger. I have like 8 motorcycles give or take I rarely ride and for years I would use this charger once a month for 24 hours on each battery all of which are stored indoors. The result was all 8 batteries would be bad whithin 2 or 3 yrs, so I was basically riding around 50 miles on each battery before it crapped. I came to the realization that either I was overcharging or the battery tender was just a waste of time and effort to use, so I got the pulse tech extreme battery charger and use it instead, but only once every 6 months or so and all the batteries were purchased 11 years ago and still fine, so my take is don't overcharge.
are u saying your battery has lasted for 15 years??
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bountyhunter
14 Apr 2011 16:54 - 14 Apr 2011 16:56I get an average life of about 6 - 7 years out of my batteries, but I leave the battery constantly connected to the charger even during riding season to keep it topped up.mark1122 wrote:bountyhunter wrote:A properly designed charger can't overcharge. If it is doing what you describe, it's either not intended for continuous (float charge) or it's just a piece of junk. I have had my charger attached to my battery steady for about 15 years.RonKZ650 wrote: No doubt every charger is different. I have a 1.25A Battery Tender that is generally regarded as a great safe charger. I have like 8 motorcycles give or take I rarely ride and for years I would use this charger once a month for 24 hours on each battery all of which are stored indoors. The result was all 8 batteries would be bad whithin 2 or 3 yrs, so I was basically riding around 50 miles on each battery before it crapped. I came to the realization that either I was overcharging or the battery tender was just a waste of time and effort to use, so I got the pulse tech extreme battery charger and use it instead, but only once every 6 months or so and all the batteries were purchased 11 years ago and still fine, so my take is don't overcharge.
I built this particular charger back in about '95 so it's been in constant use since then.
The reason my batteries last so long (aside from proper charging) is my electrical system has been modified so it disconnects all the electrics except the ignition while the starter cranks. Reducing the start load extends the life of the battery significantly.
Last edit: 14 Apr 2011 16:56 by bountyhunter.
