- Thank you received: 2103
I cant get my ignition timing to the "F" mark?????
16 Apr 2011 22:59 #445037
by Patton
Here's the pic for reference (see below).
If the heel on #1/4 is shorter for whatever reason, it's a likely suspect.
Because opening of the points will be delayed.
It's the moment of opening that causes the ignition coil to fire.
Replied by Patton on topic I cant get my ignition timing to the "F" mark?????
Patton wrote: From the pics, it looks like the heel is broken off or worn down on the left set of points.
The heel on the right set of points looks okay....
- TeK9iNe
- What did you do!?!
- Thank you received: 28
18 Apr 2011 17:04 - 18 Apr 2011 17:07 #445355
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic I cant get my ignition timing to the "F" mark?????
Dude, your points and ignition are worn to the nub. If it does work its going to be crap at best.
Its time to replace... sorry.
www.z1enterprises.com/detail.aspx?ID=200
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 18 Apr 2011 17:07 by TeK9iNe.
- dshelly
- Thank you received: 5
18 Apr 2011 21:20 #445396
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Replied by dshelly on topic I cant get my ignition timing to the "F" mark?????
Cam chain might be off 1 tooth.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- baby4arm
19 Apr 2011 00:09 #445431
by baby4arm
Replied by baby4arm on topic I cant get my ignition timing to the "F" mark?????
Okay, so I purchased a new points and condenser set. I will try it on this weekend. Carbs are all rebuilt, new accelerator pump kit on the way. I double checked the cam chain, and have correct shims now! So how would the cam chain being off a tooth affect the ignition timing? The timing rotor is bolted to the end of the crank, it should fire the plugs even with no cams or chain installed. I will try the new points. I can turn the plate enough to get the marks to line up, but they are out of the window and the bolt holes don't line up? I am ready to ride this bee-otch instead of just wrenching. Wish me luck.
- TeK9iNe
19 Apr 2011 20:09 #445678
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
If the cam chain was off a tooth it would throw the valve timing off, therefore the spark (although correctly timed to the crank) would no longer be in the optimal cam/valve timing - causes problems.
Turn the crank until the cylinder 1-4 "F" mark lines up with the case mark. This is the point that the plugs fire both the 1-4 plugs, one cylinder on the compression stroke, the other on the exhuast stroke. Time your plate/1-4 point dead on to this, then repeat on the other point with the 2-3 "F" mark.
T = Top Dead Center - no sparky here!
F = Fire mark for spark - 10 degrees before TDC - spark is here. :laugh:
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
