No spark on one cylinder
  • Topper
  • Topper's Avatar Topic Author
10 Apr 2011 10:51
#443762
I pulled my '88 KZ305 out of winter storage a week or so ago and am trying to chase down a few problems that seem to have shown up over the winter.
The latest is that I don't have any spark on the right side of the bike. I had it running and rode it around the yard last week. This weekend it wouldn't start up and it appears that I have no spark on the right cylinder.
It's not the plug, I swapped the plugs around and on the left side I've got spark and on the right none.
Is the most likely culprit a bad coil?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • martin_csr
  • martin_csr's Avatar
Re: -
10 Apr 2011 11:09 - 13 Feb 2013 11:24
#443768
Last edit: 13 Feb 2013 11:24 by martin_csr.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: No spark on one cylinder
10 Apr 2011 13:27
#443809
Make sure your getting full power to the (all) coils, and like martin said, all connections from ignition to plugs should be clean and tight.
the ignition systems not a very big deal...
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Topper
13 Apr 2011 21:34
#444482
Anybody want to help a noob?
I'm trying to test the primary and secondary resistance on my coils and my manual is not making any sense to me.
Primary:
  1. Disconnect ignition coil leads
  2. Set the ohmmeter to the x1 ohm range, and connect the ohmmeter leads to the leads from one of the ignition coils
Then my reading is supposed to be 3.6-5.4 ohms.
Ok, first problem, my multimeter doesn't have a x1 ohm range. I've got 2k - 2000k. Where do I set it? Or do I need a better multimeter?
Second problem, when they say "leads from one of the ignition coils" I don't really know what they're talking about. For each coil I have one wire running from the wiring harness to the coil and then the spark plug wire running out the back of the coil.
When I remove the lead running to the coil, there's a little tab connector there. Where am I supposed to connect the multimeter?
Secondary:
  1. Disconect spark plug caps from the spark plugs, and pull the spark plug leads off the caps.
  2. Set the ohmmeter to the x 1k range, and connect one ohmmeter lead to the spark plug lead and the other ohmmeter lead to the yellow/red lead from the ignition coil.
Then my reading is supposed to be 11-17 k ohms
Again, I don't have a x 1k range on my multimeter. Also, no yellow/red lead coming from the coil. I have leads running to the coils, but on one coil it's black/white and if memory serves the other is black/red.
I'm totally stumped on where to connect the leads in both tests and unsure if my multimeter is even up to this job.
1979 KZ750 Twin
  • MFolks
  • MFolks's Avatar
13 Apr 2011 22:27
#444492
Reading the ohm rating on ignition coils is easy, now the shop manual will list meter settings you may not have, but if your meter goes to 200, you'll still be able to read the ohms.
On most meters, the 200 is the maximum it will read, not the mimimum. You might have to buy a meter with useable ranges to be able to do checks on your bike. Radio Shack Stores sell a good, inexpensive meter along with Home Depot(look in the electrical section) and Lowes.
Disconnect any wires going to the coils as they can affect the readings and put the meter leads on the primary(small wires side) and then read between the secondary side(where the sparklug leads go)it's usually a spike the sparkplug leads go into.
  • Motor Head
  • Motor Head's Avatar
13 Apr 2011 22:34
#444494
Since you have 2 separate coils, and have swapped the plugs already, try swapping the coils. This will show you if you have a bad coil.
Tell us which meter you have, Google will pull up a reference and then you may be better advised on setting the scale. Is it Digital or Analog? Etc.
U-Tube has videos on how to test the coils and other areas of your electrical as well.
  • Topper
13 Apr 2011 23:34
#444510
So since I have two separate coils does this whole primary winding and secondary winding thing in the manual not really apply to my bike?
Here's a shot of the front of my multimeter. Will this do this job? If so what setting should I use and what results should I be hoping for when I test the coil?
1979 KZ750 Twin
  • Motor Head
13 Apr 2011 23:39
#444512
It still applies, with that meter set it to 2000 OHM. That is in a clockwise direction of your dial, the last OHM position.
Try swapping around the 2 coils. It will be a better test, it actually will test the coil under load, that's what you really want to do. It is a "Bench Test" type of thing. Swap them and see if it gets spark on the suspected coil.
  • wireman
  • wireman's Avatar
13 Apr 2011 23:56
#444516
see if you have 12v going to the coil in question,if you have 12v going to it but nothing coming out id just stick another coil on there B)
  • Topper
14 Apr 2011 00:23
#444526
wireman wrote: see if you have 12v going to the coil in question
Remember I'm a noob ;) How would I verify I've got 12v going to the coil? Lick the lead like a 9v battery? ;p
1979 KZ750 Twin
  • Motor Head
14 Apr 2011 00:30 - 14 Apr 2011 00:33
#444528
Take that Meter, put the red lead onto the red/yellow wire at the coil, and the black lead from the meter to the engine or frame= ground. Turn the key on. Oh set the meter to 12vdc.
If you would swap the 2 coils around you will be testing for power at both coils, also that the ignitor and pick up coils function. If you swap, and the coil that did work now doesn't, then more trouble shooting with the meter. But first swap coils, and check for spark.
Last edit: 14 Apr 2011 00:33 by Motor Head.
14 Apr 2011 07:03
#444548
Couldn't find a 1988 KZ305 wiring diagram, so here's my guess about the ignition system and where to attach the two ohmmeter test probes to measure the resistance of each coil.
This is a SWAG for sure, and might be incorrect, but won't hurt to try.
Am uncertain what the ohm reading should be on the particular coils at hand, but both coils should be about the same resistance.
Good Fortune! :)
