no timing light
  • toad
  • toad's Avatar Topic Author
no timing light
09 Apr 2011 09:38
#443582
Is there a way to check my timing (electronic ignition)with a multimeter?
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • Old Man Rock
  • Old Man Rock's Avatar
Re: no timing light
09 Apr 2011 09:53 - 09 Apr 2011 10:18
#443594
KZ900 FSM Dwell Angle tester yes but DVM, not likely where resolution/measurement refresh would be too slow and definitely not with any accuracy I can think of when referencing to Firing timing...
If OEM points ignition, OHMeter used for initial setup, Timing light for confirmations... May put you close enough.
Timing light is the only way to go insuring idle "F" and full advanced at 3-4K is operating to spec...
In case you need... This is out of FSM for KZ900, 98% same as your KZ1000.
Attachment KZ900PointsIgnitionTiming.JPG not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 09 Apr 2011 10:18 by Old Man Rock.
Re: no timing light
09 Apr 2011 10:45 - 09 Apr 2011 10:46
#443616
toad wrote: Is there a way to check my timing (electronic ignition)with a multimeter?
From signature, z1 1015 in a 78 kz1000 frame, guessing Dyna-S replaced points, as Kaw's electronic ignition with i.c. igniter was introduced on 1979 model KZ1000.
Dyna-S installation instructions include static timing (without engine running) by using a test bulb wired to light just as the signal wire from coil primary becomes ungrounded.
Am thinking an ohmmeter could be used in lieu of the bulb to indicate continuity or lack of continuity.
The objective is to have the bulb or ohmmeter indicate (while hand-turning the crankshaft) when the signal wire from coil primary becomes ungrounded. At which time the F mark (not T mark) on the advancer (visible through the inspection window) is supposed to align with the permanent case mark.
Static timing is better than nothing when a strobe-type timing light isn't available.
Imo, the static timing should be followed up with dynamic timing (engine running) by using a strobe-type timing light which affords more accuracy and finer tuning.
Good Fortune! :)
Last edit: 09 Apr 2011 10:46 by Patton.
  • trianglelaguna
  • trianglelaguna's Avatar
Re: no timing light
09 Apr 2011 10:46
#443617
you can get close and then get a cheap light at the auto parts tore imo...i got a decent one for 40
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • loudhvx
  • loudhvx's Avatar
Re: no timing light
09 Apr 2011 12:38
#443646
If it's the Kawasaki electronic ignition, you can get close enough to start it with eyeballing, but as Triangle says, you'll need a timing light to check for sure. The spark happens when the rotating iron pointer just barely passes the center of the pickup. That is, when the trailing edge of the point is just about lined up, or just slightly clear, of the metal center of the pickup.
If it's a Dyna S, then Patton has those instructions.
  • jjack010
  • jjack010's Avatar
Re: no timing light
09 Apr 2011 13:36
#443654
I check my static timing with a test probe/light. Then dynamic timing with a timing light. You can get the test probe/light at wal-mart, auto part stores, etc for less than 10 bucks. I have a dyna s ignition. We'll be able to better help if you tell what type of electronic ignition you're running.
1974 Kawasaki Z1
Central Texas
  • bountyhunter
  • bountyhunter's Avatar
Re: no timing light
09 Apr 2011 17:14 - 09 Apr 2011 17:18
#443683
Harbor Freight Tools probably has a cheap timing light.
Here's on for $16:
www.harborfreight.com/xenon-timing-light-3343.html
Last edit: 09 Apr 2011 17:18 by bountyhunter.
  • toad
Re: no timing light
09 Apr 2011 23:51
#443726
its dyna S. I may as well just buy the light,but good pointers indeed!
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
