needed cold cranking amps
  • Stu Pidasole
  • Stu Pidasole's Avatar Topic Author
  • if you aint mod'n, you aint rock'n!
04 Apr 2011 21:03
#442671
when buying a new battery, what cold cranking amps do i need for kz1000 with ported head, larger cams? 210, 230, 270? thanks Joe
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
Re: needed cold cranking amps
04 Apr 2011 22:30
#442681
The compression ratio will have a big affect on this as well.
Build Thread
  • Stu Pidasole
04 Apr 2011 22:38
#442682
tachrev wrote: The compression ratio will have a big affect on this as well.
10:5
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
06 Apr 2011 18:39
#443051
i will let u know what i have in my kz1200. im at work right now.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • DoubleDub
  • DoubleDub's Avatar
06 Apr 2011 19:28 - 06 Apr 2011 19:28
#443069
[strike]Static[/strike] Dynamic compression would be more important, which can change depending on valve timing.
Last edit: 06 Apr 2011 19:28 by DoubleDub.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
06 Apr 2011 20:52
#443088
mine is about 200cca.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Stu Pidasole
06 Apr 2011 21:11
#443091
mark1122 wrote: mine is about 200cca.
thanks mark:)
