Wierd ignition mod - Why would you do this?
21 Mar 2011 19:48 #439518 by KZCM
So the teardown continues and I come across this setup. There's a 4 wire set (which strongly resembles phone line) coming off the pick up coil, bypassing the IC igniter (which is taped off) and is spliced into this mess for the ignition coils.
Questions: Why would you do it?
Splicing 22 gage wire from the pick up coil to 18 gage for the ignition coils. Potential meltdown source?
I haven't tested the IC igniter yet. I'm wondering if it were bad and the PO just did this as a bypass. However, I haven't read about anything like this kind of setup.
Whaddaya think?
1977 KZ1000 - Wish I still had it
1980 KZ1000E2 - My project
  • trianglelaguna
21 Mar 2011 20:23 - 21 Mar 2011 20:25 #439528 by trianglelaguna
Replied by trianglelaguna on topic Wierd ignition mod - Why would you do this?
i think it was a dyna pick up plate and he had the wires cut too short once upon a time...so he spliced wires on the dyna sending wires to make up the shortened lengths....the gray shield n the "pick up coil" wires is my clue...post a pic oif the electronic ignition...points cover internals....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 21 Mar 2011 20:25 by trianglelaguna.
  • wireman
21 Mar 2011 20:24 #439529 by wireman
Replied by wireman on topic Wierd ignition mod - Why would you do this?
some spin off of the omr coil mod! :woohoo:
21 Mar 2011 21:09 #439543 by KZCM
I'll get a pic and post it soon. Inside the electronic ignition looks pretty clean. Are you saying this was an aftermarket type of deal that allowed the IC ignitor to be bypassed entirely? The only thing left hooked up on it was the ground. Everything else had been cut off and taped up.
  • larrycavan
  • Visitor
21 Mar 2011 21:11 #439544 by larrycavan
Replied by larrycavan on topic Wierd ignition mod - Why would you do this?
Why is everybody beating up on Dave today :silly: Last I talked to him he was headed for Florida with a tuck load of traffic cams.... I think Nebraska isn't far off his route :woohoo: I'd be careful if I were you guys :silly:
  • andy9802gt
  • If it tastes that good, eat it yourself.
21 Mar 2011 21:20 #439549 by andy9802gt
Replied by andy9802gt on topic Wierd ignition mod - Why would you do this?
trianglelaguna wrote: i think it was a dyna pick up plate and he had the wires cut too short once upon a time...so he spliced wires on the dyna sending wires to make up the shortened lengths....the gray shield n the "pick up coil" wires is my clue...post a pic oif the electronic ignition...points cover internals....
X2
looks like the P.O. hacked the wiring on the dyna for some dumb reason. the red, black and green wires in the grey sheathing scream dyna. The rest of that mess screams hillbilly.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
21 Mar 2011 21:30 #439554 by KZCM
Here's the inside. A little blurry, but like I said, it looks pretty neat. You're right about the splices on the other end. Pretty shoddy workmanship
  • andy9802gt
21 Mar 2011 21:34 #439556 by andy9802gt
that's a dyna for sure. clean up that hack job on the other end and all will be well.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • trianglelaguna
21 Mar 2011 22:04 #439563 by trianglelaguna
some stock kaw elec ignitions look like dyna in general..if it is a dyna it should say it on one of the pick ups...the reason i say there is a difference is that the stock uses the ic ignitior and the dyna does away with it...the wires get cut by folks in a hurry to part bikes and get snipped...by accidents...by idiot moves ect....i have seen this a few times on dyna s ignitions for sale on a-bay ect....the right thing for the p.o would have been clean male females and like colored gauge wires imo
1976 KZ900
2003 ZX12R
2007 FZ1000
21 Mar 2011 22:08 #439564 by Patton
Replied by Patton on topic Wierd ignition mod - Why would you do this?
KZCM wrote: 4 wire set (which strongly resembles phone line) coming off the pick up coil, bypassing the IC igniter...
Questions: Why would you do it?....
Ignition converted to Dyna-S doesn't use the stock igniter.
Dyna-S wire does indeed resemble phone line.
Good Fortune! :)
  • wireman
21 Mar 2011 22:28 #439570 by wireman
larrycavan wrote: Why is everybody beating up on Dave today :silly: Last I talked to him he was headed for Florida with a tuck load of traffic cams.... I think Nebraska isn't far off his route :woohoo: I'd be careful if I were you guys :silly:
hes traffiing bootleg cams? :ohmy: i could use a set of .410s
atleast hes not trafficing drugs! :woohoo:
  • wireman
21 Mar 2011 22:29 - 21 Mar 2011 22:31 #439571 by wireman
hes trafficing bootleg cams? :ohmy: i could use a set of .410s
Last edit: 21 Mar 2011 22:31 by wireman.
