Ratio of Mechanical Tach
- Shoey949
30 Apr 2006 10:09
Alright here's the deal. I have an '83 GPZ 550 with an '81 GPZ 550 motor. The motor has a pickup for a mechanical tach but the display uses an electrical tach. The tach is properly wired but something is wrong with the actual mechanism. So I wanted to switch to an aftermarket mechanical tach and just modify the display panel. Was wondering what ration I need and it this would work:
cgi.ebay.com/ebaymotors/Motorcycle-Chrom...dZ1QQsspagenameZWD1V
Thanks,
Nate
Thanks,
Nate
'83 GPz550H2 w/'81 GPz 550D1 engine
Dynojet Stage 3 kit, MAC 4-1, UNI Pods, DYNA coils and plug wires, WG ignition mod
Grand Rapids, MI
Grand Rapids, MI
- DanOz7Five0
Re: Ratio of Mechanical Tach
30 Apr 2006 11:13
Not really an answer but here is a thread that shows a link to some from Old Bike Barn that look just like the auction one.
kzrider.com/component/option,com_joomlab...atid,4/id,9920/#9920
- loudhvx
30 Apr 2006 22:24
You can figure out the ratio just by watching the tach drive while turning the engine over by hand.
You should also be able to use an electronic tach, if you want.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
