Acewell 2853 gauges
  • kparrott
  • kparrott's Avatar Topic Author
Acewell 2853 gauges
17 Mar 2011 12:41
#438621
I haven't been able to find gauges for my KZ750N Spectre so I'm thinking about going with the Acewell 2853:
www.dimecitycycles.com/vintage-cafe-race...eter-19-2853-bk.html
Does anyone have any experience with these?
Thanks
  • larrycavan
  • larrycavan's Avatar
Re: Acewell 2853 gauges
17 Mar 2011 14:22
#438630
I have an Acewell on my KZ. I like it but I wish it was larger.
Here's a photo so you can tell the relative size of the gauge.
Larry C
  • Grantl
  • Grantl's Avatar
  • KZRider is Da Bomb!!!
17 Mar 2011 20:19
#438706
My son Alex has one on his 83 KZ750. It works okay, but speedo is way off under 10 mph due to the sensor doesn't trip very often at that speed. We had to tinker with the wheel circumference number in the mode setting to get a speed that was close to correct. We finally got it dialed in, but it took several trial runs riding next to my car to confirm an accurate speed. It seems the faster you go, the steadier the speedo reads. At lower speeds--25 and lower, the speed reading jumps several mph's.
We installed the unit in less than a day, but you have to come up with a bracket system to mount the speedo sensor.
It also is helpful if you have a wiring schematic for your model bike--before you start splicing and cutting wires inside your headlight bucket.
The wiring instructions and different mode setting instructions that come from Acewell are very roughly translated from Japanese, and do take some interpretation. However, the wiring schematic is clear, and just depends on your ability to identify the correct wires to splice onto theirs. The RPM's (tachometer reader) is a bright yellow wire that you wrap around one of your spark plug leads (the more wraps, the better the signal)... It works well but you need to select the number of spark pulses the unit will count to display the correct RPMs... Rule of thumb, if your bike usually idles at around 1000 rpm's and the unit is indicating 2000, you know you have the pulse count number off in the Tach setting mode.
The only feature we didn't set up is the clock, as it requires a constant current to the unit. It can be hooked up by jumpering the lead that goes through your ignition switch circuit... It wasn't worth it to us to do this hookup... No big deal...
I will see if can get some pics of the speedo sensor bracket if you think it will help.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
  • Old Man Rock
  • Old Man Rock's Avatar
18 Mar 2011 03:45
#438743
You have the option for Tach pickup. As mentioned, Yellow conductor wrapped around spark plug wire or for a higher resolution of tachometer sensing, hook up directly to one of the coils primary terminals.
You'll want the sensor close to rotor magnet for accuracies... ;)
Once you dial; in for your wheel configurations and such, a little on the fly number tweaking (programming) and she'll be golden...
LUV my 2803...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • steell
  • steell's Avatar
20 Mar 2011 14:41
#439175
Have you considered either one of the following?
Veypor
KOSO
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
20 Mar 2011 16:54
#439213
Has anyone come across any similar to the acewells (round)but larger?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Old Man Rock
21 Mar 2011 06:39 - 21 Mar 2011 06:45
#439368
10 pages for Speedo/Tachs....
www.google.com/#q=autometer+speedometers...=on.1,or.&fp=1&cad=b
I realize this has been mentioned before but with the mechanical units, would need to know the Kawi ratio specs....
Dakota Digital makes some nice but spendy $$$ gauges...
Another site out of the UK...
www.digital-speedos.co.uk
Koso...
www.kosonorthamerica.com/
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 21 Mar 2011 06:45 by Old Man Rock.
  • Beard
  • Beard's Avatar
21 Mar 2011 12:12 - 21 Mar 2011 12:15
#439409
you can get a kawasaki specfic speed sensor that will fit onto the orginal speed sensor location
talk to herm at dimecity..
i think it was 15-20 bucks..
now i had to do some modify for everything ti fit correctly on my kz650
took the stock speed cable and cut it in half to get the stock collar off it..
then i had to take the new speed sensor and lightly file around the rim to make it smaller so it would fit into the stock collar nut.. not much, just a hair..
much cleaner.. and maybe u wont have to fiddle with yours.. i just know on mine.. the new speed sensor collar nut did thread onto the stock wheel speed theads.
sorry my english is horrible...
but its my only language :)
79 KZ650B
Jack of everything, Master of nothing.
Last edit: 21 Mar 2011 12:15 by Beard.
  • kparrott
21 Mar 2011 13:02
#439418
steell wrote: Have you considered either one of the following?
Veypor
KOSO
Does anyone have any info/experiences about the Veypor?
  • TexasKZ
  • TexasKZ's Avatar
  • Away
21 Mar 2011 16:56 - 21 Mar 2011 16:57
#439457
:whistle:
Last edit: 21 Mar 2011 16:57 by TexasKZ.
  • The Milkman
  • The Milkman's Avatar
25 Mar 2011 00:05 - 25 Mar 2011 00:13
#440273
I can't really say much about it yet, but I just bought a Veypor and the Indicator box with the lights on the sides. Haven't gotten it installed yet. But, what an impressive piece of equipment, if it does what it actually advertises that it does and I have done lot of reading about it and I haven't seen ANY bad reports, just praise.
As I said, I got the Veypor not the more expensive VR2, I don't need all of the extra datalogging that the VR2 does.
I also got the silver indicator box they were out of the black one. They emailed me that the black ones were a limited run.
You can veiw them at: veypor.com/index.html
For a total of 298 buckazoids with shipping and quick delivery. I'm impressed with them.
Oh, I did check with them and they said all I have to do is email them with the mileage that is now on the bike, they will send me a firmware patch to load into the Veypor so it shows the correct mileage on the odometer.
Les
Last edit: 25 Mar 2011 00:13 by The Milkman.
  • XL777
  • XL777's Avatar
07 May 2011 02:53
#449380
I just bought a 2803 and its great! Only problem I'm having is the speedo cable threaded cap you buy to fit the Kawasaki stock speedo cable is slightly bigger so it wont stay on tight. I'm going to try some lock tight ;) we will see. Anyone else see this happen?
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
