gauge bulbs
  • hoopcatjc
  • hoopcatjc's Avatar Topic Author
gauge bulbs
15 Mar 2011 09:13
#438131
new to the site here. Just brought home a 1980 KZ750 with 7500 actual miles. The bike is perfect except that the tach is not illuminated. Anyone have insight to the quickest way to get to those bulbs? thanks in advance.
  • deers45
  • deers45's Avatar
  • KZ 900
Re: gauge bulbs
15 Mar 2011 09:24
#438134
pull the tach,spedo mounting bracket off and the tach. cover has a small screw on the end. 2 nuts hold the tach onto the mount. pull the tach off the mount and then you can get to them
76 KZ900 DEERS45
  • MFolks
  • MFolks's Avatar
Re: gauge bulbs
15 Mar 2011 12:03
#438146
The light bulbs may be of the push and turn type or the #168/#194 baseless bulbs.
  • martin_csr
  • martin_csr's Avatar
Re: -
15 Mar 2011 12:17 - 11 Feb 2013 18:23
#438150
Last edit: 11 Feb 2013 18:23 by martin_csr.
  • hoopcatjc
Re: gauge bulbs
15 Mar 2011 19:05
#438250
I'll give that a try, it is a Four. It has a small cafe-style fairing that will have to come off.
  • MFolks
  • MFolks's Avatar
Re: gauge bulbs
15 Mar 2011 19:20
#438256
If the bulb holders are rubber, use a light coating of silicone grease(rub it on with your fingers, this prevents the holders from drying out and cracking.
  • cbewley
  • cbewley's Avatar
Re: gauge bulbs
24 Aug 2012 17:15 - 24 Aug 2012 17:19
#544554
Found this post. Having same problem with my 81 750/4. I can't get to the bulbs.
I read in other posts you just have to pry them out the back. Is that correct?
I also read about cutting the chrome ring with a dremel to get to the innards and JB welding it back together.
I took it all screws out and nothing seems to budge, and I don't want to break anything. Cutting the ring seems pretty extreme just to change some bulbs.
Attachment tach.jpg not found
PS: These "Captcha" codes are quite hard to read
'81 kz750H with '77 650B motor
Last edit: 24 Aug 2012 17:19 by cbewley.
Re: gauge bulbs
24 Aug 2012 17:18
#544555
You don't need to cut anything to replace the gauge bulbs. Just remove the gauge and the bulb holders pull out of the back of the gauge. Ed
  • cbewley
  • cbewley's Avatar
Re: gauge bulbs
24 Aug 2012 17:23
#544558
Thanks Ed. I tried pulling em out, but they're in there pretty tight. I gave up before I screwed anything up.
Re: gauge bulbs
24 Aug 2012 17:29
#544563
It might help to put a little rubber lube on them where they connect with the gauge body. Just be sure not to get the lube inside the body or it might affect the gauge internals. Ed
  • MFolks
  • MFolks's Avatar
Re: gauge bulbs
24 Aug 2012 18:22
#544571
Get some silicone spray, put some on a cotton swab, apply it to the bulb holders & let it work for a while. The rubber bulb holders are probably stuck to the back side of the instruments.
  • Mickey1031
  • Mickey1031's Avatar
Re: gauge bulbs
27 Aug 2012 19:22
#545145
cbewley wrote: Found this post. Having same problem with my 81 750/4. I can't get to the bulbs.
YEA! I AGREE!!
guess I'm blind glad to know i have company lol
i would look at the base of those bulbs and see if you can change them to L.E.D. or replacement L.E.D. bulbs so you wont have to go threw all of this again.
If you cant find them as a ready made you can buy L.E.D.'s on Ebay real cheap and get the correct resistor and make them your self.
did the whole dash in a monte carlo the was "un serviceable" also a Freight liner Classic. so they can hold to the vibration either way
The difference between a "biker" and a real Biker, saying you own a bike, and actually owning a bike, Not a "T" shirt
