KZ550 No spark ....but
- TONY_G
14 Mar 2011 04:27
hi guys,
My KZ550 cafe project nearly done,new wiring the lot looking pretty sexy.
Here is where my problem lies,When i crank over the bike no spark, but when i short across the pickup coils i get a good strong spark to the plugs.
Tested the pickup coils readings are good.
any help?
any help?
- Old Man Rock
Re: KZ550 No spark ....but
14 Mar 2011 04:29 - 17 Mar 2011 03:36
LoudHVX who's you want to speak with/PM....
He knows the ins & outs of the 550 series not to mention his electrical/electronic knowledge ... Pretty smart guy...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 17 Mar 2011 03:36 by Old Man Rock.
- loudhvx
17 Mar 2011 03:11
First thing to do is verify the pickups are good and provide signal, at least some of the time.
Unplug them from the igniter, and make sure they have no connection to the engine or any other ground. You said they had continuty to ground, but I assume that was while they were still connected to the igniter. Also make sure they have no continuity to each other.
Red to yellow should have continuity as you measured, and black to blue also.
There should be no connection from red or yellow to black or blue.
To verify signal output, check this page on magnet polarity and do the screwdriver/voltmeter test. Both pickups should produce a similar size pulse if you move the screwdriver similarly for the two pickups.
Next make sure the rotor looks like the one pictured.
Testing pickups and polarity.
Next make sure you get spark on both coils by whatever method you were using. Swap the coils if you have to. And remember both plugs on one coil must spark at the same time so make sure both are grounded to engine when checking. Not having both plugs touching the engine while testing can blow the coil.
So if both coils can produce spark, and the pickups are good, then it is likely the igniter has been damaged. You can confirm by getting another one to test, or you can try to build one.
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- CoreyClough
- GPz550 Addiction
17 Mar 2011 04:29
Remember, Lou does like beer! :woohoo:
'85 GPz550(ZX550-A2)
- TONY_G
17 Mar 2011 18:46
YES BABY....Lou is the guru
Checked the magnet poles put it back in all good.
and yes i do owe you a beer or 6
if you ever get your self to OZ the beers are on me:)
