coil repair? is it possible
  • steveo_4192003
  • steveo_4192003's Avatar Topic Author
  • 77kz650b-1
29 Apr 2006 18:48
#43756
my bike, stock 1977 kz650b
ok so my bike ran ok until i took out the old plugs (one at a time) and put new ones in!
i looked around the site but only found few related posts.
the coil wire, at the coil#2 is very loose and rotates around in the coil!!!but wont come out i think it may have come undone and/or broke inside.
can this be fixed? i think they are seald
i belive they are stock coils for my 77 kz650b! they say ( tec )on the side of them. i should get new ones but have to wait until funds allow me to!
thanks heres a pic
Post edited by: steveo_4192003, at: 2006/04/30 14:56
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
  • neilage66
  • neilage66's Avatar
Re: coil repair? agian!
29 Apr 2006 18:51
#43757
To look at the coils on my GPz, I thought they were hardwired but I gave the little "bullet" a twist and...lo and behold the connector unthreaded and allowed easy replacement of plug wires.
I've been told that some coils are hardwired and some aren't...I lucked out. :P
  • steveo_4192003
  • 77kz650b-1
Re: coil repair? agian! or swap!
29 Apr 2006 19:11
#43763
i forgot, i have a good pair for my 72 cb500!
they are stock also, but can i use them on this bike???
if anyone knows please let me know! pretty sure the wire is broke inside the coil, ill test tonight!!
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
29 Apr 2006 19:21
#43766
Get out the OHM meter. If the primary resistance is similar they'll probable work fine.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • steveo_4192003
  • 77kz650b-1
Re: coil repair? is it possible
30 Apr 2006 12:06
#43934
hers a few pics of the suspect coil #1-#4! looks like it got hot and fried the inside or something im going
right now im going to get coils from my cb500 thats stored away and try them to see if they work,
  • steveo_4192003
  • 77kz650b-1
03 May 2006 12:00
#44830
i tried to use the honda coils but would not fit in mount! so i put old ones back on! well i got the bike going, so it was not a coil!
i think i didnt have fuel reaching engine, as it would backfire through carbs!(means it lean i think) i cleaned petcock (agian) and turned on ,waited for a minuite and choked it and she fired right up. no problems so far. i road for 2 block or so and she went very well. but coils will need replaced here soon!!
Post edited by: steveo_4192003, at: 2006/05/03 15:03
  • wiredgeorge
  • wiredgeorge's Avatar
03 May 2006 12:39
#44840
I would toss those coils and buy new ones with removable plug wires... Dyna coils work well and are reasonably priced at www.z1enterprises.com
If you don't have the money, buy new plug wires, some epoxy and cut off the old plug wires and drill them out carefully. I think most are just inserted onto a metal barb and then sealed with epoxy. Push the new wire into the hole and make sure the metal lead inside the wire contacts the barb. Then seal with epoxy again.
It would probably be easier to buy new coils.
