static timing possible issue
  • stonemaster
  • stonemaster's Avatar Topic Author
12 Mar 2011 18:58 - 12 Mar 2011 19:30
#437523
setting static timing a little while ago and had an interesting issue, its been a while since I've done it but i dont remember having to have the ignition on to do so, I'm using a continuity only tester. When the key is off, and I separate the points, I still get a beep, but when the key is on the beep stops when the points open as per the manual and my experience. Is this correct?/ i have a new wiring harness from Z1 ignition switch and all. The lights work as they are supposed to, no fuse blowing or anything,the starter works as well so no ther apparent electrical problems... Please advise
thanx
confused :blink:
EDIT
I can get the beep to stop with the key off but I HAVE TO SPREAD THE POINTS alot
Last edit: 12 Mar 2011 19:30 by stonemaster.
  • stonemaster
Re: static timing possible issue
12 Mar 2011 20:56 - 12 Mar 2011 21:14
#437557
got it B)
I am using a non powered tester so key has to be on
Last edit: 12 Mar 2011 21:14 by stonemaster.
  • loudhvx
  • loudhvx's Avatar
12 Mar 2011 21:20
#437560
There are two (or more ways) to do it.
One way is with power on and use a voltmeter to time it.
The other way is with no power at all and using an ohmeter/continuity tester. To do this, you have to time one set of points at a time, but you have to slip a paper card into the other set of points. This is because the two sets of points have a common wiring point at the coils. To isolate one circuit at a time, you have to slip a piece of paper into the other points so they make no contact.
  • stonemaster
12 Mar 2011 21:29 - 12 Mar 2011 21:32
#437562
thanx i got it ( I had voltmeter)but will remember ur info for future reference
what threw me off on that was one: I was using a different tool that last time and two : my other bike has only one set of points
Last edit: 12 Mar 2011 21:32 by stonemaster.
  • wireman
  • wireman's Avatar
12 Mar 2011 21:38
#437564
this is the tool i was talking about,of course i havent jacked with a set of points in a llllllllllllllong time.and even back then i wasnt that great with the damn things! :laugh:
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
12 Mar 2011 21:43
#437566
You're still using points... :huh: :P :laugh:
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • stonemaster
12 Mar 2011 22:00
#437569
yes I am and will continue, I can fix points in a pinch , electronic well ur screwed :blink:
