Rectifier / Connectors / Pins
- DoubleDub
11 Mar 2011 14:50 - 11 Mar 2011 14:51
While examining my wiring, I found a mess at my rectifier. Multiple breaks in shielding, obvious scorching on the white output wire, and two of the yellow wires in the male plug had shorted melting the plug holder.
Anyways, I cam across this post by LoudHVX in the Kzrider Archives while trying to be cheap and replace the rectifier only (regulator appears to be good still).
Lou - you mention in the thread I found this at that you had a better design? Is this design sufficient to replace the factory rectifier? Also, what gauge wire would you recommend?
Last edit: 11 Mar 2011 14:51 by DoubleDub.
- DoubleDub
Re: Rectifier / Connectors / Pins
11 Mar 2011 14:51
Also, does anyone know if it is possible to buy the male connector and pins for the factory wiring harness? I would prefer this over removing the connectors and replacing them with something different, but will if necessary.
- stonemaster
11 Mar 2011 15:02
Z1 enterprises has all that stuff, blocks, pins, etc,
- DoubleDub
11 Mar 2011 15:04
I looked and they didn't seem to match up to the stock female connectors. I'll double check again.
- stonemaster
11 Mar 2011 15:07
if ur talking about the blue connector block they should have em or know where to get em, if not I have a spare bloc I THINK
- DoubleDub
11 Mar 2011 15:12
The rectifier connector on my bike is white, but yes, the same 6-pin type connector.
The one I found on Z1 Enterprises doesn't have the keying like the factory one does, I'll have to ask them if it works.
www.z1enterprises.com/detail.aspx?ID=2952
- stonemaster
11 Mar 2011 15:14
sorry ur right white is correct, if they dont I got a white one too, its got a scorched pin but the case aint melted or anything
- MFolks
11 Mar 2011 15:22
Try these websites:
Electrical Connectors
www.easternbeaver.com
www.vintageconnections.com
www.z1enterprises.com/catalog.aspx?pid=KPEL1
www.vehicle-wiring-products.eu
www.electricalconnection.com
www.electricalconnection.com/electrical-components/hitachi.htm
11 Mar 2011 15:25
DoubleDub wrote:
Try these folks:
HVC Cycle
Vintage Connections
Try these folks:
HVC Cycle
Vintage Connections
