Electric speedometer?
  • les holt
  • les holt's Avatar Topic Author
  • Vendor
  • Vendor
10 Mar 2011 15:54
#436860
I'm building a Z1R custom as some of you may know, My target was to use as much Kawasaki parts as possible but opted to use autometer gauges. In doing so I need a speed sensor to run the speedometer. I got to thinking I could use a speed sensor off a newer sportbike. Not having 1 to look at, how do they pick up their signals? Is it off tabs on the sprocket or possibly off the teeth themselves? Also, I need the pinouts off the sensor to hook up mine. Does anyone have any resources for this info?
Thanks guys!
  • NZGlenn
  • NZGlenn's Avatar
Re: Electric speedometer?
11 Mar 2011 14:23
#437095
I've been looking at another form of speedo as the old cable etc is too inaccurate, especially as the cops over here are cracking down on speeding. They don't have quotas just have to issue so many speeding tickets per shift!
Anyway, I reckon the way to go would be a gps speedo. I know you can get tomtom/garmin/etc, but I haven't seen one that actually is designed as a speedo. That would be pretty cool:woohoo:
1984 GPz1100A2
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
12 Mar 2011 07:37
#437319
I think most modern sport bike speedometer sensors pick up their signal from the counter shaft in the trans.
The magnet is not on the sprocket itself.
Build Thread
  • les holt
  • Vendor
  • Vendor
12 Mar 2011 10:23
#437368
I had assumed that the newer sportbikes would use a hall effect sensor "3 wire" where a magnet isn't required, only needs to read a ferris material passing by it. Guess I'll look elsewhere. Thanks
  • les holt
  • Vendor
  • Vendor
13 Mar 2011 05:59
#437605
Got it, using a speed sensor off an 03 ZX6, turns out to be a 3 wire hall effect sensor, exactly what I needed.
  • tachrev
  • tachrev's Avatar
13 Mar 2011 09:10
#437654
Cool, good to know.Wasn't thinking hall effect for some reason.
Makes more sense.
I just found out that the CBR900RR uses a hex drive off the sprocket bolt. The sensor bolts inside the sprocket cover.
Might be something else to look at.
Build Thread
