wheres waldo?
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
wheres waldo?
08 Mar 2011 09:26
im starting this thread so i dont hijack adams awesome build thread.
wheres the electronics on these bikes?
- Stu Pidasole
- Stu Pidasole
- TeK9iNe
- What did you do!?!
Re: wheres waldo?
08 Mar 2011 09:43 - 08 Mar 2011 09:44
Are you referring to a specific set of the electronics?
I can still see the wiring looms coming from the control pods, and you can see the main harness passing through the triple on them... ?
If you mean batt, and R/R, solenoid etc. Sometimes they just dont have the batt, charging system at all.
Stupid.. .i know. I had a friend ride like this. He kicked his bike to start it, then tossed the kicker aside, and just let it run all the time, even at fuel ups.
If he wanted to stop for an eat, hed have to bump start it. he used just a little battery and a capacitor setup, which to me - seemed to take about 1/2 much space as a battery.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 08 Mar 2011 09:44 by TeK9iNe.
- Stu Pidasole
Re: wheres waldo?
08 Mar 2011 09:52
yeah, wheres the batt and wire cluster? i see plug wires and then.....nothing.
- DoubleDub
Re: wheres waldo?
08 Mar 2011 10:21
Yep, even the green one on top has the kicker-gear exposed. I would guess they are running loss-less(?) and are kick starting.
- TeK9iNe
Re: wheres waldo?
08 Mar 2011 10:27
Could be just "show setups" as well. May not even be 100% functional right now.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- hal0tw0
Re: wheres waldo?
08 Mar 2011 10:47
Eventually Im going this route.. Im building a custom seat and you can stuff a small scooter battery under the seat area. You have to chop/splice your harness and you can hide things under there and also under your tank. Theres room....you have to get creative. just Take off your seat, tank and covers and start to mod away. In the process you can make a custom harness to be just bare bones too
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
- loudhvx
Re: wheres waldo?
08 Mar 2011 20:57 - 08 Mar 2011 21:04
I bumpstart only. It's pretty easy on a 550.
If the bike has a permanent magnet alternator, then it has a good chance of running with no battery at all. It gets replaced by a capacitor. I actually have two there, but one is not connected. It's just a spare capacitor, but I haven't had any problems in over 3 years.
I also have a very efficient ignition, which helps. I run two 55 watt halogen headlights.
All of the electrics fits under the seat.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 08 Mar 2011 21:04 by loudhvx.
- MFolks
Re: wheres waldo?
08 Mar 2011 21:06
Are you using thermal compound(the white Zinc stuff) for heat transfer on the regulator/rectifier and the GM modules?
- loudhvx
Re: wheres waldo?
08 Mar 2011 21:13
I designed the ignition so that it wouldn't really heat up the modules (like they do in a car). They are slightly warm to the touch with no heat sink compound, but they do need to be bolted to some aluminum just in case.
The reg/rec was never mounted with heatsink compound, and it gets about as warm as any other, but it gets more air where it is, so heat has not been an issue with it.
1981 KZ550 D1 gpz.
Other links.
Other links.
Re: wheres waldo?
09 Mar 2011 06:21
lou,thanks for posting pics of this bike again.
your bike looks killer!
did you ever ride it around with the glowing larvae thing in the tail?
