Dyna/coil mod question (another one)
- dkmk
28 Apr 2006 19:38
Waiting on chassis parts, so I have assembled all the parts to install a Dyna-S and the relay mod. Just want to verify where I am tapping in for the power for both the relay, and for the Dyna-S. Handlebar housing has both a brown wire, and a yellow/red striped wire. All the other hook-ups for the relay are straight-forward. I just want to get it right the first time. :laugh: Thanks, here are a couple of pics:
Thanks in advance.
Post edited by: dkmk, at: 2006/04/28 22:38
Post edited by: dkmk, at: 2006/04/28 22:40
Thanks in advance.
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
- rstnick
Re: Dyna/coil mod question (another one)
28 Apr 2006 19:50
It's the red/yellow wire you want. In your last pic, you have the red/yellow wire with the dual female plug. Unplug the coils, run a single wire from the dual female plug to lug 86. Then from lug 87, run a wire to your coils. I cut a dual female plug off another scrap harness and attached it to this wire from the 87 lug, and plugged in the 2 coils. Here's a diagram:
Post edited by: rstnick, at: 2006/04/28 23:01
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Biquetoast
- King Jeremy The Wicked
28 Apr 2006 19:55
dkmk wrote:
I guees you're following the old version of the "coil mod" doc, the one that says to tap into the handlebar control wire.
I just ran a wire from the starter solenoid for the POWER power to the relay. I used the old coil power wire as the trigger for the relay. Then I used 87 and 87a from the relay to power the coil and the ignition.
...Just want to verify where I am tapping in for the power for both the relay, and for the Dyna-S. Handlebar housing has both a brown wire, and a yellow/red striped wire...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- rstnick
28 Apr 2006 20:07
Here's a diagram of how I set up mine with a 5 lug relay that had two #87 lugs. I used one 87 lug to power my IC Igniter, but it can be used to power the Dyna in your case.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- dkmk
29 Apr 2006 01:36I guees you're following the old version of the "coil mod" doc
Yes, that is the one. I think I am getting hung up on wire colours, as the brown wire from handlebar is connected with a 2 -> 1 connector, but you will notice there is only a single wire.
I too have the double #87 lugs on the relay, so I can use one for the Dyna power, correct? Why does the diagram show #87 -> Igniter -> ground? Never looked to close at the Dyna yet, and briefly skimmed the instructions. Will check later.
Thanks for the help, will be back if required :laugh:
Northern Ontario
- rstnick
29 Apr 2006 10:20
The diagram with the Igniter I drew up for my Electronic Ignition Conversion. The Dyna will connect just like the Igniter, although I'm not sure if the Dyna has a ground.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
